Results 1 to 10 of 11
July 12th, 2010 03:58 PM #1
Hello Guys. I need your help. I drive a 10-year old Civic. The temperature gauge shoots up if I don't accelerate. It even shot up to the red line already yet there is water in the radiator and engine is not overheating (no steam, etc). The gauge goes back to normal is the car is steady at 2000rpm. At Idle, I have to pump gas at 2000rpm for the gauge to goes down. What are the possible issues? Thanks very much
July 12th, 2010 04:10 PM #2
could be, most probably your engine temp sensor going bad or a loose/dirty socket connection. In most engine you could find it near the intake hose of the radiator going to the water pump. Pull out the socket connection and see if your temp drops to zero.
July 12th, 2010 04:20 PM #3
I am also thinking there might be some air inside the water jacket. The bubble of air got temporarily stuck at the sensor resulting in a sudden increase in detected temperature.
July 12th, 2010 04:24 PM #4
thanks all for the help. Regarding the air in the water jacket, what should be done to rectify this?
July 12th, 2010 04:27 PM #5
July 12th, 2010 04:50 PM #6
you may also want to check-out the thermostat and e because these may get busted or not read signals correctly if there is a lot of buildup around those things.
hth
July 12th, 2010 06:03 PM #7
*Ghosthunter - if I ask my talyer to flush out the radiator and refill with new coolant/water mix, will that solve the issue? thank you so much for your help.
*baludoy - sige, i will have the thermostat check din. but it seems I've been getting responses even from friends that baka nga may air sa water jacket.
July 12th, 2010 06:05 PM #8
*Ghosthunter - if I ask my talyer to flush out the radiator and refill with new coolant/water mix, will that solve the issue? Your DIY suggestion seems easy for a girl like me to do, siguro I can try it out nga first thank you so much for your help.
July 12th, 2010 04:23 PM #9
Sir, thanks very much for the quick response. I've noted what you advise and will take my car to my old reliable talyer to have the engine temp sensor checked. thanks!
Problem sa super dark tints is the tint itself and thus your window gets warm. Sure direct...
Best 3M tint series (ranking)
