Results 1 to 4 of 4
- May 2009
- 28
July 14th, 2010 11:30 PM #1Recent problem:
Pag naka on ang aircon for quite sometime lets say 30-1hour humihina ang hatak ng car sa first and second gear kahit sagad ang pedal sa floor. napansin ko to usually pag yung temperature gauge lumagpas ng konti sa half. yung aux motor fan is naka rekta na siya, once nag on ang car on na din ang fan. car is opel astra sedan. sana may makatulong. thanks
July 14th, 2010 11:50 PM #2
nag-aagawan ng kuryente ang spark igntion system (gasoline engines need currnt to generate sparks to continue running the engine) mo, aircon at ang other electricial components ng kotse mo. Try buying a bigger alternator as a solution. Old cars tend to have this agawan issue.
July 15th, 2010 12:09 AM #3
A volt-meter gauge would show you the voltage of the system. If the reading falls from 14 volts to 12 volts, it confirms that your alternator is not producing enough current at idle for your car with a/c running.
- May 2009
- 28
July 15th, 2010 09:05 AM #4thanks. so walang kinalaman yung fan? may instance pa pala na muntik ng mag overheat yung kotse nung heavy traffic ako sa edsa. Pinatay ko aircon then nawala then bumaba temperature. San pala ok mag pacheck ng alternator? Qc area sana. Thanks.
With this sort of gadget the thing to keep in mind is "you get what you pay for". I've been in...
Rear view mirror dashcam, help me choose...
