Nag overheat Liteace namin this morning sa Ayala avenue....i asked the driver of my mom to take it to a gas station baka kulang lang sa tubig. (i was at Betan getting a carbon clean for the paj).
Anyway meron talyer malapit sa BETAN pinatingin nung driver. Iniwanan ko na was late for a meeting.
Nilinis radiator then pinaandar. Pag naka on yung aircon lumalagpas gitna yung temp.
Kapag hindi naman...no problem. Dinrive makati to ortigas after without aircon hindi nag overheat.
Umaandar naman yung aux fan. Yung water sa radiator umiikot naman pag ni rev (so i guess umaandar yung water pump). .
Nasa C5 kami just a few minutes ago pauwi pinaandar ko yung aircon ok lang di nag init (below middle yung temp) pero pagdating sa bicutan exit na medyo traffic....there it goes again up to the middle. Pinatay ko na yung aircon and the temp stayed just below middle. I guess its a problem of not getting enough air to cool the radiator. Yung fan hindi clutch kaya permanent fix. Aux fan kaya? Umaandar pero baka not enough power?
I think its the auxillary fan. It may be funtioning pero its not giving enough speed/air to the condenser. Also have the fan coupling (fan clutch or clutch fan whatever you like to call it) checked. Also have both the condenser and your radiator sprayed with water to clear it fom any debris.
It maybe possible that its an electrical problem. Layo ano? Well its because potentially low ang electricity. So even if the aux fan is running its not running fast enough. I had a similar problem dati, the fix was just to tighten the screw on the ground.
FRT, try this madalas di alam ng mga mekaniko ito... yung radiator fan( the fan connected to your engine) may parang clutch yun. in time yung silicon oil sa loob natutuyo kaya bumabagal ikot. pwede yun buksan at lagyan lang ng silicon oil mga 2-3 tubes (about 150 each) depende kung gaano katuyo na yung oil sa loob... whats hapenning to your liteace happened to my tamaraw fx, and hi-ace also yun lang ginawa at ok na temp nila ngayon.
to know kung silicon oil nga do the following:
1. while the engine is off open the engine bay
2. with your finger push the radiator fan.
3. pag umikot ang fan blades ng parang electric fan na naka-off... silicon oil nga.
oh i forgot... yung rad fan usually magagalaw mo talaga sya ng fingers mo (PAG PATAY MAKINA HA) pero ang movement nun mga half a blade lang ang galaw when you nudge it.
yes it's common to have some plastic sucked into the radiator and this blocks the air flow. hindi naman lahat ng lite ace sakit ang overheating as mentioned earlier.
Had the same problem, same vehicle. After all was said and done, the problem was a leaking radiator cap. Ngayon, kahit tirik ang araw, full blast ang aircon (front/back), walang problema.
Buti na lang hindi ako nakinig dun sa mga kumag na mekaniko!
had the same problem before, 3/4 temp ko and wondrin how come,dahil doble aux fan na nga nilagay ko sa tapat ng condenser & rad, yun pala may plastic bag na na suck ng aux fan ko.. usually happens pag trapik ka sa mga market area..
Mine also is overheating very fast.... meron ba kayo alam sa Abad Santos area na nag-clean or overhaul ng radiator?? Ang bilis tumaas ng temp pag ON ang aircon, if OFF naman ok naman ang temp... TIA..
Another question, lahat ba ng liteace GXL may aux fan sa harap ng condenser?? i did not check mine if it has kasi when i open the driver seat( atop of the engine) , I can only see the engine Fan cooling the radiator....TIA..
