Results 21 to 40 of 41
    Apr 2005
    #21
    from abad santos Lrt station going to chinese cemetary, may mga radiator repair shop duun try mo na lang.
    Jun 2005
    #22
    madalas thermostat, pero sakit talaga ng lite ace ang overheat lalo na sa init sa phils mga iba dinadagdagan ng aux fan paltan m n din mg bago aux fan m bka mahina na. tapos gawa ka optional na switch kasi malakas sa kuryente aux fan. try mo pagawa sa mga nag aircon.
    Jan 2003
    #23
    Lite Aces are CBU, am i right? I guess, the reason why they are prone to overheating is that they have relatively small radiators not suited for Phil. climate, in other words, they are not tropicalized.
    Jun 2005
    #24
    im having problems w/ my liteace din. ang dami ko na nagagastos because of overheating.
    first is the replacement of the gaskets and the cylinderheads were "shaved" in a machine shop. then pinalitan yung pinagkakabitan ng radiator cap. hindi na gaano tumataas yung temp.
    then after 2 weeks i saw a very very small leak sa radiator. i had it fixed. pero after a month, umiinit na naman.
    saan kaya pwede magpagawa ng mas magandang radiator for the liteace? magkano kaya?
    Feb 2005
    #25
    One of the radiator shop ( REAL RADIATOR SHOP) quotes me to clean/overhaul the radiator for 1.2k.. ok na ba price nito?? it takes 3-4 hours ang job nato..
    But he told me one month warranty lang sa leak, NO WARRANTY sa overheat...
    WBR
    Jun 2005
    #26
    innova_boy, ano auto mo?
    sa akin, nagbayad ako sa talyer ng 800pesos to remove my radiator kasi mahirap daw tanggalin ang radiator ng liteace as compared to cars. i think tinanggal pa nila yung seats ko just to remove the radiator. tapos sila na ang nagdala sa radiator shop somewhere in e.rod. the radiator shop checked and sealed the leaks for 450pesos. so a total of 1250pesos.
    if you have a car, malamang mas mura sa 1250.
    Feb 2005
    #27
    Liteace GXL... kaya lang ang main problem ko is overheat... kaso say nila NO WARRANTY on overheat, hanggan LEAK LANG SILA..
    I'm having second thoughts on having it cleaned tapos mag-overheat din after a week..
    Tanong ko lang lahat ba ng LITEACE may aux fan in front of condenser?? kasi on my ride di ko makita kasi nakaharang sa ilalim yung condenser ng rear aircon sa ilalim..
    WBR<
    Feb 2006
    #28
    Quote Originally Posted by Innova_Boy
    WBR<
    elo we got the same problem dre... ung skin din nilinis ung radiator den d na sya nag over heat for almost 3 weeks pero after 3 weeks ganun na nman..d k p na try maglagay ng coolant e...ok lang b maglagay ng coolant sa lite ace..? ang liit kc masyado ng radiator nya...sabi nung iba sa forum gawin daw 3 rows kya lang wla ko makita gumagawa mismo ng radiator sila lang daw ung pede mag upgrade nun...
    Nov 2006
    #29
    Bakit sabi nila maliit ang radiator ng Liteace. Pero nung tinigna ko radiator ng Liteace ko malapad sya, kasing lapad ng evaporator. Or baka naman manipis ang ibig nyong sabihin? Can't compare sa ibang Liteace kasi hindi pa naman ako nakakita ng ibang Liteace. BTW kabibili ko lang kasi nito. and I want to improve it's performance, hindi ko pa naman na-experience ang mag-overheat, and I don't want that to happen.
  10. #30
    ung akin nag overheat because of clogged radiators, ang ginawa ko, pinalinis ko, ok naman, then pinapalitan ko yung labi na pinaglalagyan ng cap at yung cap mismo, then i poured ung "quick fix" na sealant for cooling system(for those troublesome pinholes), kasi di nagppresurized yun system ko, hindi nya hinihigop ulit ung laman ng "puke-tank",e...hope by this time humigop na siya.sana makapagpalit na ako din ng alternator para constant at max. speed ang mga aux fans ko, even under full load(aircon,lights,wiper,AV-system).
    mines a 2c-te matic 4wd, kaya mas madaming factors din kaya nagooverheat(may turbo, at matic) compared sa local na manual tranny at non-turbo engine pero kasi ung akin dual-radiator syatem na, stock JDM set-up po yun, kaya, i refuse na mag-overheat liteace ko...ma 3 aux fans at 1 clutch fan(na di fixed)pa...
    ang wala lang sa liteace ko na gusto ko palagay are oil-coolers(for the engine and matic) at kung papalarin, dadag-dagan ko ng intercooler ang air intake piping-->para intercooled-turbo siya)
    Jun 2007
    #31
    Our family wants to get a lite ace, paano ko malalaman kung may over heat problem cya? patukbuhan ko ang makina ng 15% na may A/C ba ????
    Jan 2003
    #32
    Quote Originally Posted by eeebay View Post
    Ibilad mo sa araw, tapos running at idle only, buksan mo aircon full blast. Check how long before the temp needle goes beyond halfway, if it does at all. This should simulate a bad traffic day on EDSA.
    As for the other questions here, our Lite Ace has 3 fans, the viscous clutch fan on the engine and one electric fan each on the 2 condensers. That's how it was when we got it 4 years ago. I think the fan on the condenser next to the radiator was just added on, judging from the mounting brackets used. IOW, obvious na hindi stock.
    I've never had overheating problems with this vehicle since the radiator cap fiasco I posted earlier on this thread.
    I don't know if this is still relevant, medyo matagal nang na-post yung mga tanong e, but HTH.
    #33
    Most of the time repair shops recommends repairing or replacing radiators, replacing cylender head gaskets, etc. What evryone should do is first try simple solutions first before they get into the hard ones, like cleaning the condensers in front of the radiators with high pressure water and soap and rinsing it for about five minutes solves most overheating problems.
    Check also the radiator cap if it has no leak and correct pressure. Also advisable is putting 50/50 coolant and distilled water. This does not stop overheating per se but it maintains cleanliness of the radiators and the engine block which prevents them from rusting, preventing future overheating.
    #34
    We experienced the same problem. Pag nakatigil ng matagal and the aircon is running, umaakyat ang temp. Nawawala din ang lamig ng aircon.
    The problem was caused by the auxilliary fan ( hindi umaandar.) There are 2 fans on the radiator, and only 1 was spinning. If the aircon is ON, dapat parehong umiikot yun.
    Just pop the hood, and check if both fans are spinning.
    May 2009
    #35
    mga boss! newbie here... i just bought a 1994 toyota liteace gxl sabi ng may ari bago bilhin ang problema nga daw is your overheating pag halimbawa traffic tumtaas ang temp lalo na pag nak on yung aircon...so ang gingawa niya daw pinpatay niya lang yung aircon sa likod tapos nag no-normalize na daw ang temp...tapos na consult na daw niya sa mechanic niya about the problem...ang sabi daw dapat paghiwalayin yung condenser sa radiator...kasi magkatapat daw yun...question is... totoo ba to? or may nakatry na ba sa inyo nito? baka kasi sayang lang gastos tapos ganun din pala... meron din nagsabi na magdagdag daw ng aux fan...ano ba dapat sir ang best possible solution??? help naman dyan...salamat!
    Aug 2004
    #36
    Quote Originally Posted by budoy77 View Post
    Do both... add an aux fan and move the radiator condenser. But adding a powerful auxiliary fan should be enough.
    Jan 2003
    #37
    Kung walang thermostat, lagyan mo ora mismo.
    May 2009
    #38
    ok ty...try ko gawin yan..salamat
    Jun 2006
    #39
    Feb 2012
    #40
    Quote Originally Posted by impulzz View Post
    FRT, try this madalas di alam ng mga mekaniko ito... yung radiator fan( the fan connected to your engine) may parang clutch yun. in time yung silicon oil sa loob natutuyo kaya bumabagal ikot. pwede yun buksan at lagyan lang ng silicon oil mga 2-3 tubes (about 150 each) depende kung gaano katuyo na yung oil sa loob... whats hapenning to your liteace happened to my tamaraw fx, and hi-ace also yun lang ginawa at ok na temp nila ngayon.
    to know kung silicon oil nga do the following:
    1. while the engine is off open the engine bay
    2. with your finger push the radiator fan.
    3. pag umikot ang fan blades ng parang electric fan na naka-off... silicon oil nga.
    hope this helps
    paano mapapaikot sir e naka konekta nmn ung belt ng fan sa alternator?
Liteace overheat due to aircon?
