Results 31 to 40 of 89
- Nov 2009
- 3,509
December 5th, 2019 08:17 PM #31Just stick to the original design, get the cheapest Taiwan replacement. Taiwan quality is par with orig, its dirt cheap you could get 3 for a price of the casa.
As per my experience, thermostats fail only due to poor maintenance ie. not replacing coolant on reco interval, using tap water only with contaminants causing sediments and rust buildup that eventually calcify hardens on the orifice and moving parts of the thermostat valve. Removing thermostat could cause poor fuel economy.
- Feb 2017
- 28
December 5th, 2019 09:53 PM #32
Maybe 3 years or even more.
was hoping may nakapagtry na dito with their crvs using 2 rows, dapat nga siguro 1 row nalang since yun nga ata ang stock.
looking now for evercool like the one posted online laz, since dami good review but a friend told me good daw ang made in thailand.
December 6th, 2019 08:00 AM #33
While you're at it. Palitan mo na rin lahat ng hose and then since papalitan mo na rin hose, palitab mo na thermostat para isang gawaan na lang.
December 6th, 2019 08:55 AM #34
December 6th, 2019 09:00 AM #35
- 54,299
December 6th, 2019 09:26 AM #36i am curious. i don't honda.
is there a difference between the gen 1 radiator and the gen 2 radiator?
December 6th, 2019 09:27 AM #37
- Feb 2017
- 28
December 6th, 2019 09:37 PM #38
thank you sa reply. You mentioned of thermostat do i need to replace thermostat when replacing radiator? mukang taiwan made nga talaga makukuha ng friend konsa evangelista para tumingin, if he cannot buy one then baka evercool brand na cheapo not the 11k evercool bit the one found in online shops.
i dont think i need to replace the hoses also hindi naman kasi nag overheat.
right on the coolant yun mechanic kasi na pinagpalit ko ng coolant i had that feeling na hindi gumamit ng distilled kaya siguro naglawang and nag crack. masama mag bintang but ireally had that feeling.
- Feb 2017
- 28
December 6th, 2019 09:44 PM #39
December 6th, 2019 09:49 PM #40
