Quote Originally Posted by jvnj View Post
Sir vin247,
If you already checked / applied the suggestions made by our Tsikot Guru's, try also checking your radiator clutch fan if it is loose already. Loose clutch fan is very inefficient in cooling your radiator specially at high RPM's, thus causing high temp and probably premature water evap.
Sir its a AT transmission wala ata clutch fan?
Quote Originally Posted by miko101130 View Post
i second this motion.. haha... malaking role ng clutch fan in maintaining your temperature.... pag dumudulas na yan hihina hatak hangin sa raditor pati sa condenser...
