Results 1 to 20 of 29
    Feb 2013
    Thanks sa mga reply mga sir! My van is Mitsubishi Delica 1992 model, when my radiator tend to loose 1.5 liter of water last week when i go out of town, going to work and i experience traffic. I always check my radiator everyday before going to work yesterday EDSA day so theirs no traffic when i check this morning wala naman bawas yung radiator ko. Im planning to put coolant and pa linis na rin ung radiator ko i sabay ko na sa tune up. Thanks so much mga sir well appreciated mga reply's niyo !
    Sir vin247,
    If you already checked / applied the suggestions made by our Tsikot Guru's, try also checking your radiator clutch fan if it is loose already. Loose clutch fan is very inefficient in cooling your radiator specially at high RPM's, thus causing high temp and probably premature water evap.
    Dec 2009
    Quote Originally Posted by jvnj View Post
    Sir vin247,
    i second this motion.. haha... malaking role ng clutch fan in maintaining your temperature.... pag dumudulas na yan hihina hatak hangin sa raditor pati sa condenser...
    Feb 2013
    Sir vin247,
    Sir its a AT transmission wala ata clutch fan?
    Quote Originally Posted by miko101130 View Post
    Jan 2004
    sir yun clutch fan is the 2nd aux fan yun isa kasi is for the aircon
    Dec 2009
    Quote Originally Posted by vin247 View Post
    Sir, yung clutch fan na tinutukoy dito ay yung "clutch fan kung saan naka-connect front blade ng fan sa harap"
    pag sumilip ka sa sasakyan at rear wheel drive, makikita mo after the raditor yung puti na blade, naka-attach yun sa clutch fan....
    iba yung sa clutch ng manual transmission
    transmission clutch
    Radiator clutch fan
    Sir vin,
    Sir miko was right, the clutch we're mentioning is the clutch which holds the radiator fan blades. Try manually rotating the fan with your hands (of course with the engine off), if there is no restriction at all or very minimal, then it is loose already. You might have to recharge it with silicon oil or replace.
    Dec 2009
    sa experience ko repalcement clutch fan is cheap compared to orig na para sa spefici vehicle pero malayo ang performance nila at itatagal...
    mas makapit at accurate yung clutch fan na orig sa pag control ng silicon oil sa loob mechanism, thus mas makapit,, mas makapit clutch fan mas malamig... mas happy ang raditor at condenser...
    Feb 2013
    Sir vin,
    Mga sir im very sorry i was so noob hehe sige sige ill try it later. Next sat ko pa kasi visit yung friend ko na mechanic then ill post the result. Thanks sa mga advice mga sir
    Feb 2009
    it is not a smart idea to open your radiator cap daily. the manufacturer never intended for the owner/operator to break the seal every time. there will be a considerable wear and tear on the sealing surfaces between the radiator cap and the radiator neck. no car owners manual tells you to open it on a daily basis. maybe every oil change would be okay. annually, have the antifreeze checked for protection level, pressure test the cooling system and check the other related items like the fan clutch, radiator fan switch and relay, fan belt, etc. follow the vehicle owner's manual service intervals. your intentions are good but the results might be detrimental to the cooling system
    Feb 2013
    Sir Jick i dont have my manual of my Delica 1992 model actually we acquire it last 3 yrs lang so i dont know if where is the owners manual. Anyways thanks sir for reminding and giving tips well appreciated!
    Sir vin,
    I did own a Delica 2002 before and I would tell you, not having a manual is not a problem. Given the common 4D56T engine of our Delica's, most technicians are very familiar with it. And I bet given that jurrasic (but very reliable!) engine of Mitsu, in time, you can easily understand its basic maintenance.
    I would say, until now, I really miss that truck!
Radiator problem!
