Results 21 to 30 of 287
March 31st, 2017 07:36 AM #21
Thanks mga sirs sa inputs nio. At least may idea na ko ng pwede cause ng overheating
baka may kakilala kayong naghohome service na mekaniko. ayoko na sana ibyahe. Guadalupe, Makati Area
Sent from my SM-J700F using Tsikot Forums mobile app
March 31st, 2017 07:37 AM #22
Last thing na ginawa ko for cooling system is nagchange ako ng motor ng fan ng radiator last year
- May 2011
- 481
March 31st, 2017 08:03 AM #23
- May 2013
- 140
March 31st, 2017 10:23 AM #24Kung nagbabawas ng tubig/coolant at walang leak, I would replace the radiator cap.
- 54,283
March 31st, 2017 11:59 AM #25
- May 2011
- 481
March 31st, 2017 08:52 PM #27
What is your reference level for the coolant fluid?
The coolant fluid container is marked F and L
If your reference is above F then its normal because F should be maximum level of the fluid. As in the proper level should be F and below for the coolant fluid, while F and above should be air
Why that should be the case? Build up in heat result in greater pressure which push that fluid level above the F mark. If you filled the the coolant container up to the brim, then that will be indeed the case, there will always be reduction in fluid level, as long as its not below L mark, then the coolant level should be ok
If you carefully inspect the coolant container, there is an overspill hole on top. That takes care of excess fluid upon pressure build up, it discharge excess coolant fluid due to pressure expansion
The best practice in filling up coolant is up to F mark level only
Sent from my GT-P3110 using Tsikot Forums mobile appLast edited by kisshmet; March 31st, 2017 at 08:59 PM.
March 31st, 2017 10:50 PM #28
sa simpleng pressure test e masshoot siguro ang problema nyan.......
kahit yung bicycle pump, tire valve, silicone sealant at kung may extra ka na radiator cap or yung pinagpalitan mo na rad cap pupwede na. google nyo po kung pano gumawa ng simpleng aparato para sa pressure test.
April 2nd, 2017 02:34 AM #29
Update mga sirs
So, last night pinuno ko ng tubig yung expansion tank and radiator. pinaandar ko yung makina for 40mins with aircon. di naman tumaas temp. Sabi ko sa sarili ko pwede ng mabyahe to from Guadalupe to Banawe (Jorge Radiator).
nakarating ako sa banawe (8am), no aircon. baka itirik ako.
ang naging solution ni mekaniko, overhaul ng radiator.
Ok na sia mga sirs. d na sia nagooverheat kahit tirik and araw and may Aircon. salamat sa lahat! The best talaga sa Tsikot!
- 54,283
April 2nd, 2017 08:17 AM #30
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
