Results 1 to 10 of 34
September 12th, 2007 05:00 PM #1
-parang napansin ko once in w hile pag nagchecheck ako ng 2big sa radaiator may konting putik sa ibabaw. anong cause nito? i dont use any chemicals and just use pure water. balak ko sana pa flush then mag coolant na ako.. ano po kaya possible cause?
September 12th, 2007 05:03 PM #2
September 12th, 2007 05:13 PM #3
yup accumilated rust.. kung may time ka, pa- top and bottom overhaul mo yang radiator mo (genaral radiator overhaul)
depende sa size, 900 to 1500 lang yun... kaysa naman maging cause pa yan ng overheat mo....which can lead to bent cylinder head...
September 12th, 2007 05:24 PM #4
sandali lang po ba mag pa overhaul ng radiator? may nabasa rin akosa old threads na pag pwede tangalin ang drain plug ng radiator tapos lagyan ng host ung ibabaw tapos hintayin na luminis ung lumalabas na tubig is it effective din?
September 12th, 2007 05:34 PM #5
Putik? Kulay Milo? Naghahalo na rin ba yung tubig at langis sa loob ng radiator at reserve tank, pa-check mo na rin yung headgasket. Baka may tama na.
Pa-flush at pa-overhaul mo na rin mo na rin yung rad mo para sure. Mura lang naman, P450 lang ang top overhaul.
September 12th, 2007 05:35 PM #6
But it might not be enough to remove the rust that have accumulated at the bottom of your radiator. Think of mud that has time to thicken over time. A simple hose with running water will not be enough to remove it.
Rust might also be clogging the small passages of your radiator fins so an overhaul would be needed to clear them of these rust deposits.
September 12th, 2007 05:43 PM #7
September 12th, 2007 05:44 PM #8
mga anong range ang price ng overhaul ng radiator?honda esi po ako... ung maliit lang ang radiator single row lang ata
September 12th, 2007 05:45 PM #9
Try mo pa overhaul ang radiator mo, saan ba ang loc mo kasi sa cavite city rad overhaul 350petot only, incl rem/installation ng radiator, tanggal cover taas at ibaba, sundot lahat ng water lines (alis bara). man hours 3.
Xiaomi E-Car
