Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
    Try the Lavramon service (kay Autotechnika meron... and i think kay JP Wheels in Paranaque din). Cleaning only the radiator won't be much help as the sludge will also be inside the engine cooling channels (*where the coolant runs through in the engine block) so once you clean the radiator, chances are it will get dirty again.
    Jun 2006
    Dallas Caltex in Tomas Morato also offers Lavramon. Dont know how much they charge.
    Quote Originally Posted by raine View Post
    Try mo pa overhaul ang radiator mo, saan ba ang loc mo kasi sa cavite city rad overhaul 350petot only, incl rem/installation ng radiator, tanggal cover taas at ibaba, sundot lahat ng water lines (alis bara). man hours 3.
    last week po nag palinis ako ng radiator, cost 700pesos, near sta. lucia mall.
    Feb 2007
    just do it yourself, buy oxalic acid in any of those mercury drug outlets
    try using turco you can buy it at the local hardware store
    Jun 2006
    What does oxalic acid do? And how are you supposed to use it?
    Turco, isnt this a brand of rust converter?
    Feb 2005
    Quote Originally Posted by shampooking View Post
    Quote Originally Posted by morco View Post
    care to teach us how to use these?
    Sep 2004
    May radiator flush na ba Turco? Alam ko meron sila rust converter, pero its meant to be painted on a metallic surface, not poured.
    Hindi rin ako familiar sa oxalic acid.
    it's not a radiator flush your right as it is a rust converter but it it is a good product used as radiator flush, use it only as a cleaning agent flush out after administed not intended to be left inside the radiator
    May 2007
    oxalic acid, di ba yun ginagamit sa pampaputi ng damit?
RADIATOR (may putik sa loob)
