Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Sep 2006
    -parang napansin ko once in w hile pag nagchecheck ako ng 2big sa radaiator may konting putik sa ibabaw. anong cause nito? i dont use any chemicals and just use pure water. balak ko sana pa flush then mag coolant na ako.. ano po kaya possible cause?
    Quote Originally Posted by MasterZerg View Post
    it could be minerals from the water you used or rust. Are you using ground water?
  3. #3
    yup accumilated rust.. kung may time ka, pa- top and bottom overhaul mo yang radiator mo (genaral radiator overhaul)
    depende sa size, 900 to 1500 lang yun... kaysa naman maging cause pa yan ng overheat mo....which can lead to bent cylinder head...
    Sep 2006
    sandali lang po ba mag pa overhaul ng radiator? may nabasa rin akosa old threads na pag pwede tangalin ang drain plug ng radiator tapos lagyan ng host ung ibabaw tapos hintayin na luminis ung lumalabas na tubig is it effective din?
    Sep 2004
    Putik? Kulay Milo? Naghahalo na rin ba yung tubig at langis sa loob ng radiator at reserve tank, pa-check mo na rin yung headgasket. Baka may tama na.
    Pa-flush at pa-overhaul mo na rin mo na rin yung rad mo para sure. Mura lang naman, P450 lang ang top overhaul.
    But it might not be enough to remove the rust that have accumulated at the bottom of your radiator. Think of mud that has time to thicken over time. A simple hose with running water will not be enough to remove it.
    Rust might also be clogging the small passages of your radiator fins so an overhaul would be needed to clear them of these rust deposits.
    sandali lang magpa overhaul mahihintay mo, then use coolant.
    Sep 2006
    mga anong range ang price ng overhaul ng radiator?honda esi po ako... ung maliit lang ang radiator single row lang ata
    Try mo pa overhaul ang radiator mo, saan ba ang loc mo kasi sa cavite city rad overhaul 350petot only, incl rem/installation ng radiator, tanggal cover taas at ibaba, sundot lahat ng water lines (alis bara). man hours 3.
  10. #10
    sinabi ko na sa taas--900-1500
    Try the Lavramon service (kay Autotechnika meron... and i think kay JP Wheels in Paranaque din). Cleaning only the radiator won't be much help as the sludge will also be inside the engine cooling channels (*where the coolant runs through in the engine block) so once you clean the radiator, chances are it will get dirty again.
    Jun 2006
    Dallas Caltex in Tomas Morato also offers Lavramon. Dont know how much they charge.
    Quote Originally Posted by raine View Post
    last week po nag palinis ako ng radiator, cost 700pesos, near sta. lucia mall.
    Feb 2007
    just do it yourself, buy oxalic acid in any of those mercury drug outlets
    try using turco you can buy it at the local hardware store
    Jun 2006
    What does oxalic acid do? And how are you supposed to use it?
    Turco, isnt this a brand of rust converter?
    Feb 2005
    Quote Originally Posted by shampooking View Post
    Quote Originally Posted by morco View Post
    care to teach us how to use these?
    Sep 2004
    May radiator flush na ba Turco? Alam ko meron sila rust converter, pero its meant to be painted on a metallic surface, not poured.
    Hindi rin ako familiar sa oxalic acid.
    it's not a radiator flush your right as it is a rust converter but it it is a good product used as radiator flush, use it only as a cleaning agent flush out after administed not intended to be left inside the radiator
    May 2007
    oxalic acid, di ba yun ginagamit sa pampaputi ng damit?
RADIATOR (may putik sa loob)
