Results 101 to 110 of 127
March 10th, 2009 12:30 PM #101
Sa akin naman bumababa yung level ng water sa radiator, after a few days of use, pero sa reserve tank hindi. Siguro ang naidadagdag ko na water is 1/2 glass to fill it up again. Tapos medyo may malapot na kulay kalawang sa may lip/opening ng radiator.
I had my radiator overhauled a month ago. Sa tingin ko nagkaroon ng leak sa radiator na hindi pa ganun kalaki as of now. Pero bakit po kaya hindi bumababa yung sa reserve to fill up the radiator?
- May 2006
- 7
March 21st, 2009 09:31 PM #102meron din ako problem tubig ng radiator nababawasan nakita ko palagi napupuno ang reservoir ,nagawa ko na lahat palit ng gasket gn cylinder head, resurface ng cylinder head, palit ng takip ng radiator ,palinis ng radiator ,tumatapon pa din ang tubig sa reservoir di naman na tumatapon o bumubula ang tubig sa radiator pag umaandar sakit na ulo ko kung ano pa dahilan ng sasakyan ko baka meron dito may experience ng ganito patulong naman mga brod
March 23rd, 2009 10:18 AM #103
Just an update i had my radiator overhauled at Jorge Radiator Shop sa banawe. This was recommended by Otep. Ok na sya. Ok na cooling system. Check nyo din drain plug baka madami na bungi mga paps. Sa akin kasi may tagas din dun.
- Feb 2009
- 36
March 24th, 2009 01:36 AM #104mine had the same issue, and yesterday nag overheat yung car ko... buti na lang naagapan pa...
my radiator top already had a crack and the epoxy can't hold to it any longer... good thing at di pa ako nakakalayo sa area namin...
i don't know kung napamahal ako or kung tama yung decision ko... pinapalitan ko ng tanso yung radiator top... it cost me Php 2,200 (kasama na yung overhaul)... i researched here in the forum and found na yung iba ginawa din ito...
correct me if i'm wrong, the radiator top (denso yung brand) would cost around 7k to 8k? well... medyo tight budget as of this moment, so i had no other choice...
anyway, the car is doing fine as of the moment...
March 25th, 2009 09:39 AM #105
- Feb 2009
- 36
March 26th, 2009 07:13 AM #106kung wala overhaul mga 1,500 lang.. pero sayang naman kung di ko pa overhaul e binaba na rin naman yung radiator... pero may nagsabi sa akin na mahal daw pero di naman sinabi kung magkano aabutin kung dapat e mura... so until now clueless ako kung napamahal ako... pero ok naman yung kotse ko so ok na rin ako...
March 27th, 2009 03:15 AM #107
July 20th, 2009 12:19 AM #108
habol ko lang nung pag ka overhaul ng pregio due to overheating isa din pala nag cacause ng water losing ang water jacket goma pala ito pwede din pag tapunan ng tubig at di agad nakikita ,,kung di babaklasin ang engine,
- Feb 2009
- 36
July 31st, 2009 02:58 AM #109i have another temperature problem... buti na lang sakto pag park ko sa bahay... nagkaron ng cut yung lower radiator hose... after palitan.. ok na.. but then, pagkagamit ko kanina napansin ko nawala yung lamig nung aircon... parang blower lang sya... possible kaya na natuyo ang freon?
August 10th, 2009 07:04 PM #110
Any idea how much is a surpluss rad for a civic AT 1999 model kasi sakin nag crack yung plastic top na tapos I had it replaced and repaired 3x kasi hindi nila makuha I am thinking that I should get a surpluss please give me your views on this
TIA
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
