Results 11 to 20 of 58
- Nov 2002
- 22
December 10th, 2002 07:35 AM #11guys gawin nyo twice a year kayo magflush ng radiator
para di mag accumulate ng daming dumi radiator and
less hassle in the long run.
December 12th, 2002 05:34 AM #12
... or before the summer season. That way ready na yun radiator mo for the hot months.
December 12th, 2002 11:55 AM #13
Originally Posted by chieffy
December 12th, 2002 02:02 PM #14
distilled water.. ito ba yung water rin na nilalagay sa mga batteries??....
- Dec 2002
- 21
December 12th, 2002 02:19 PM #15yes, distilled water yung nilalagay sa batteries. Iba iba rin kasi ang nga bottled waters, yung Absolute is distilled, yung iba naman e mineral water at yung nabibili sa water refilling stores e purified. So kung distilled ang kailangan, just check the bottle na distilled nga ito.
December 12th, 2002 02:37 PM #16
so yung absolute e pwede ring battery fluid?. mahal nga lang.. eheheh...
hmmm... masubukan nga yan.. pinaplano ko na rin naman kasing i-flush yung rad ko eh....
so ano ba dapat talaga process?. use a flushing solution?. o just drain it.. run a hose on top, wait until the water coming out at the bottom starts to become clean, then close the plug, fill it with coolant/water (distilled) mixture then go??
so far yan ang ginagawa ko. drain, use hose, then plug, then fill with tap water lang... walgn coolant...
May 7th, 2003 08:15 AM #17
Ako din due na yata for flushing.
What i'll do is to drain the water from the radiator and put a hose with running water while engine is running. Tapos kapag malinis na i'll put a 50/50 mixture ng distilled water and coolant sa reservior tapos i'll put it in the radiator then fill the remaining with water.
Tama ba ang gagawin ko? :D
Brian GuestMay 7th, 2003 11:52 AM #19
Originally Posted by Djerms
