Results 21 to 40 of 41
    Feb 2019
    #21
    Quote Originally Posted by nightfox View Post
    thanks for the replies. however, the real reason I'm asking is - have you heard of that case (played/told on the video) re: cancer-causing agents?
    I believe the video also told that there are still cancer-causing agents even if not parked under the sun (for e.g., at night). hence, at night, the windows should be open by the time you switch on the AC.
    what do you think?
    closes the doors on one side to "push" the hot air through the open doors of the opposite side
    May 2009
    #22
    I would hope that most of us living here in our tropical paradise that is Da Pilipins would and should do this. It's just logical to allow hot air to vent out before using the A/C.
    One thing I won't do though is start the car and open the windows. The exhaust gasses will always find their way into the cabin.
    #23
    Hello everyone, how true is this? (please see the video link below)
    https://video.fmnl17-1.fna.fbcdn.net...=5CA2B5F5&dl=1
    It says on the video that windows should be lowered so that the air inside the car (while it was switched off) will go outside. The air that was stored there especially during high temperature is cancer-causing (the mixing of burnt plastics and other chemicals). How true is this?
    Video Link on Facebook: https://video.fmnl17-1.fna.fbcdn.net...=5CA2B5F5&dl=1
    this is my opinion only.
    it is probably true, the carcinogens part.
    but as someone above already said, overblown.
    you'd probably have to live in the hot car with closed windows, 24/7, for over a decade, to be even remotely cancerized.
    May 2009
    #24
    The fried food we eat, the sugar-laden drinks and the proteins full of antibiotics will cause more cancer than any hot interior, tama po ba Doc?
    #25
    Quote Originally Posted by sparc179 View Post
    "i don't care."
    basta masarap.
    seriously,
    if we think about the potential carcinogenic effect, baka back to cavemen style na tayo. as in, raw, free-range food.
    May 2009
    #26
    "i don't care."
    basta masarap.
    seriously,
    Hahaha, so true. Live and eat what you want, we're all going to die someday anyway.
    Besides, who wants to live forever anyway? Not me that's for sure.
    ako antayin ko muna mawala malfunciton indicator lamp tapos doon ko start tapos doon ko na ibaba windows then baba ako kotse mga 5minutes balik ako tapos bukas ko na aircon na nakababa pa din bintana.
    Kung baga syempre nakulob pasingawin ko muna.
    #28
    ang gastos mo naman sa fossil fuel.
    ang galante mo naman sa air pollution.
    doc from cold start lang yan at pag hindi ko naparada sa may bubung. Pero ganun talaga ako doc lagi ko baba bintana pag matagal nakaclose.
    Ayoko na gawin yung ibaba bintana tapos hindi nakastart engine. Nadiskargahan ako dati pinaglaruan ko kasi. Close open close open. Ang bilis pala makadrain yan.
    Jan 2009
    #30
    How to use a hot car (na hindi nakaw):
    1. Get in
    2. Start the engine
    3. Turn on A/C
    4. Crack open the windows, drive off, then close them after 15 seconds
    #31
    1. Get in
    2. Start the engine
    3. Turn on A/C
    kags,
    you should read this.
    eh doc nasa australia ata yan si oj. Eh dito pinas ngayon summer kulang 15seconds para nasa turbo broiler steamer.
    Pag bukas ko pa lang pintuan grabe init nakakapaso. Minsan hindi na ako umuupo abutin ko direcho key ignition tapos yun ang tagal lang mawala malfucntion indicator lamp. Doon sa civic ek ko talaga tutunog pa click pag nawala si M.I.L. Mga bago kotse ngayon tahimik na pag nawala.
    Chaka ngayon lang naman doc dahil nga super summer ito.
    Daming kaaartehan naman. I don't even lower the window kahit na nabilad sa araw pag bukas ng a/c auto mode full blast naman agad eh within minutes hinde na mainit.
    Nov 2012
    #34
    Kung bago sasakyan di na kailangan. Kung medyo luma na (5 yrs and up), ginagawa ko open ac then labas ako at antay lang muna sa labas tapos after mga 5 mins, pasok na ulit. Hayaan lang sumingaw init.
    Sent from my LDN-LX2 using Tapatalk
    Feb 2019
    #35
    then baba ako kotse mga 5minutes balik ako tapos bukas ko na aircon na nakababa pa din bintana. Audacity Find My iPhone Origin
    karamihan takot mag full blast hahaha. baka masira daw hahaha
    Pag may auto climate.. auto ko na agad para siya na bahala mag adjust para ma reach ang temp...
    Oo tama naman ibaba yung bintana para sumingaw. Amoy plastic kaya kotse tapos paano kung nag-iiwan pa plastic bottles.
    Yung full blast aircon gawin ko lang yan pag normal na temperature kung baga nakabwelo na.
    Sinasayang ninyo lang oras ninyo sa kung ano-anong kaaartehan ginagawa.
    Jul 2013
    #40
    I dont open the window. I open the doors to let the hot air out fast.
    Yes you can use auto climate - mag full blast yan to reach the desired temp asap.
    But high school physics will tell you that it is faster to cool a space with a temp of 30 degrees celcius air than one with 40 degrees.
Lower The Windows Before Switching the Aircon On - Should this be the practice?
