Results 1 to 10 of 14
- Oct 2010
- 11
October 17th, 2010 08:35 PM #1Honda accord 1997
tanong ko lang saan maganda magpaayos ng radiator? near Las Pinas lang
nilinis na yung radiator (overhaul). nacheck na din na wala DAW LEAK, mababa naman ang temp nya (city driving) pero pag long drive like going to tagaytay nagooverheat siya.
ano inputs niyo dito mga sir? ano kaya sira neto? and saan pede ipaayos? near Las Pinas lang sana.
October 17th, 2010 08:42 PM #2
have your radiator hoses checked baka me leaks na. Also, check if the clips attaching the hoses to the radiator and engine block are tight. And check for leaks around the thermostat assembly (connecting the upper radiator hose to the block). And finally check if your car is emitting white smoke sa exhaust baka (hopefully hindi) me leak na cylinder head gasket mo.
- Oct 2010
- 11
October 17th, 2010 08:48 PM #3chineck na ng mekaniko yung mga hose din e. pero sabi nila wala naman daw leak. and dun sa white smoke? ang alam ko wala pong nalabas na white smoke
san po ba maganda ipacheck to? near LAS PINAS lang po
October 17th, 2010 08:51 PM #4
- Nov 2009
- 456
October 17th, 2010 10:41 PM #5*Polista
Have the radiator cap checked or replaced if it is more than 4 years old. The spring underneath may not be doing its job to release internal pressure when needed. Make sure the replacement is of the same spec as the original.
- Dec 2006
- 234
October 18th, 2010 05:50 AM #6
- Oct 2010
- 11
October 18th, 2010 08:31 AM #7oww. sige po try ko muna palitan ng radiator cap.
San po ba kayo nagpapaayos ng radiator? any inputs? para kung sakaling hindi radiator cap ang problema
October 18th, 2010 08:51 AM #8
I have my radiator fixed at Mang Joe's, near Rizal High School in Sixto Antonio Ave Pasig. This is near Pasig Rotonda. Ilang dekada na nandun yung Joe's Radiator Shop, kilala na siya dun. Pero dahil sobrang liit nang shop, 1 customer at a time lang puede.
May thermostat pa ba ang Accord mo? Baka natanggalan na ng thermostat, at ikot lang nang ikot ang tubig. For long drives, the radiator will not have the chance to cool down the circulating water, kasi ikot lang nang ikot eh. The thermostat is supposed to keep water from circulating, so the radiator is able to cool down the temps, when thermostat opens due to high temp, it will release the hot water back to the radiator, and take in the cooled down water, then shut off uli ang thermostat.
October 18th, 2010 09:11 AM #9
*TS - sir I bet, pure tap/distilled water lang ang gamit niyo? tama po ba?
you said kung normal city driving lang, no overheat. kung long drive overheating ka. tandaan na ang water maganda ang cooling power pero mabilis maabot ang boiling point, hence in long drive umaabot na ng boiling point ang water.
my recommendation, put 50-50 coolant in your radiator. in your reservoir naman, pure coolant. unahin mo muna itong gawin sir, yung ibang recommendations na nabasa ko dito masyado kaagad malala, always start from the basics.
October 18th, 2010 09:56 AM #10
Assuming all other things are good i.e. clean rad, good cap, good tstat, good CH gasket, etc...another thing to look for is the radiator lower hose. it could be collapsing (even w/o leaks). the reason is that the water pump creates negative pressure (vacuum) in the water jacket esp during high speed thus the highway overheat.
Plus, checking the cap operation:
1. Compress if it can be compressed (for relieving pressure)
2. Pull the inner spring if it can be pulled (for relieving vacuum)
Traffic!
