oww. sige po try ko muna palitan ng radiator cap.
San po ba kayo nagpapaayos ng radiator? any inputs? para kung sakaling hindi radiator cap ang problema
I have my radiator fixed at Mang Joe's, near Rizal High School in Sixto Antonio Ave Pasig. This is near Pasig Rotonda. Ilang dekada na nandun yung Joe's Radiator Shop, kilala na siya dun. Pero dahil sobrang liit nang shop, 1 customer at a time lang puede.
May thermostat pa ba ang Accord mo? Baka natanggalan na ng thermostat, at ikot lang nang ikot ang tubig. For long drives, the radiator will not have the chance to cool down the circulating water, kasi ikot lang nang ikot eh. The thermostat is supposed to keep water from circulating, so the radiator is able to cool down the temps, when thermostat opens due to high temp, it will release the hot water back to the radiator, and take in the cooled down water, then shut off uli ang thermostat.
*TS - sir I bet, pure tap/distilled water lang ang gamit niyo? tama po ba?
you said kung normal city driving lang, no overheat. kung long drive overheating ka. tandaan na ang water maganda ang cooling power pero mabilis maabot ang boiling point, hence in long drive umaabot na ng boiling point ang water.
my recommendation, put 50-50 coolant in your radiator. in your reservoir naman, pure coolant. unahin mo muna itong gawin sir, yung ibang recommendations na nabasa ko dito masyado kaagad malala, always start from the basics.![]()
Assuming all other things are good i.e. clean rad, good cap, good tstat, good CH gasket, etc...another thing to look for is the radiator lower hose. it could be collapsing (even w/o leaks). the reason is that the water pump creates negative pressure (vacuum) in the water jacket esp during high speed thus the highway overheat.
Plus, checking the cap operation:
1. Compress if it can be compressed (for relieving pressure)
2. Pull the inner spring if it can be pulled (for relieving vacuum)
Try mo sa Fermin, sa may AirForce One, dyan ako nag pa palit ng radiator top ko. Ok naman service nila, nothing special.
JOPREMAR ENTERPRISE
Fermin Aircon, Electrical and Radiator Shop
Address: 1291-A Quirino Ave, San Dionisio, Paranaque City
Contact to Jovi or Shirley Marquez
Tel: (02) 829-3771 / 775-2293 / Globe- 0915-5413610 / Smart 0921-7169898 / 0918-4314519
email to: JMarquez3*slb.com or jovi1645*hotmail.com
