Results 1 to 14 of 14
    Honda accord 1997
    tanong ko lang saan maganda magpaayos ng radiator? near Las Pinas lang
    nilinis na yung radiator (overhaul). nacheck na din na wala DAW LEAK, mababa naman ang temp nya (city driving) pero pag long drive like going to tagaytay nagooverheat siya.
    ano inputs niyo dito mga sir? ano kaya sira neto? and saan pede ipaayos? near Las Pinas lang sana.
    have your radiator hoses checked baka me leaks na. Also, check if the clips attaching the hoses to the radiator and engine block are tight. And check for leaks around the thermostat assembly (connecting the upper radiator hose to the block). And finally check if your car is emitting white smoke sa exhaust baka (hopefully hindi) me leak na cylinder head gasket mo.
    chineck na ng mekaniko yung mga hose din e. pero sabi nila wala naman daw leak. and dun sa white smoke? ang alam ko wala pong nalabas na white smoke
    san po ba maganda ipacheck to? near LAS PINAS lang po
    Jul 2010
    Quote Originally Posted by polista View Post
    Honda accord 1997
    parehas tayo sir ng problem with my b2500..
    *Polista
    Have the radiator cap checked or replaced if it is more than 4 years old. The spring underneath may not be doing its job to release internal pressure when needed. Make sure the replacement is of the same spec as the original.
    Quote Originally Posted by CivicVTi View Post
    *Polista
    I also have a 97 Accord with the same problem. City driving is fine, but long drives at ~100Kph along SLEX/NLEX with the aircon on caused it to overheat.
    Turns out it was the radiator cap. Bought a 1.1 bar rated cap from speedyfix and all was fixed.
    oww. sige po try ko muna palitan ng radiator cap.
    San po ba kayo nagpapaayos ng radiator? any inputs? para kung sakaling hindi radiator cap ang problema
  8. #8
    I have my radiator fixed at Mang Joe's, near Rizal High School in Sixto Antonio Ave Pasig. This is near Pasig Rotonda. Ilang dekada na nandun yung Joe's Radiator Shop, kilala na siya dun. Pero dahil sobrang liit nang shop, 1 customer at a time lang puede.
    May thermostat pa ba ang Accord mo? Baka natanggalan na ng thermostat, at ikot lang nang ikot ang tubig. For long drives, the radiator will not have the chance to cool down the circulating water, kasi ikot lang nang ikot eh. The thermostat is supposed to keep water from circulating, so the radiator is able to cool down the temps, when thermostat opens due to high temp, it will release the hot water back to the radiator, and take in the cooled down water, then shut off uli ang thermostat.
    Jun 2010
    *TS - sir I bet, pure tap/distilled water lang ang gamit niyo? tama po ba?
    you said kung normal city driving lang, no overheat. kung long drive overheating ka. tandaan na ang water maganda ang cooling power pero mabilis maabot ang boiling point, hence in long drive umaabot na ng boiling point ang water.
    my recommendation, put 50-50 coolant in your radiator. in your reservoir naman, pure coolant. unahin mo muna itong gawin sir, yung ibang recommendations na nabasa ko dito masyado kaagad malala, always start from the basics.
    May 2009
    Assuming all other things are good i.e. clean rad, good cap, good tstat, good CH gasket, etc...another thing to look for is the radiator lower hose. it could be collapsing (even w/o leaks). the reason is that the water pump creates negative pressure (vacuum) in the water jacket esp during high speed thus the highway overheat.
    Plus, checking the cap operation:
    1. Compress if it can be compressed (for relieving pressure)
    2. Pull the inner spring if it can be pulled (for relieving vacuum)
    Try mo sa Fermin, sa may AirForce One, dyan ako nag pa palit ng radiator top ko. Ok naman service nila, nothing special.
    JOPREMAR ENTERPRISE
    Fermin Aircon, Electrical and Radiator Shop
    Address: 1291-A Quirino Ave, San Dionisio, Paranaque City
    Contact to Jovi or Shirley Marquez
    Tel: (02) 829-3771 / 775-2293 / Globe- 0915-5413610 / Smart 0921-7169898 / 0918-4314519
    email to: JMarquez3*slb.com or jovi1645*hotmail.com
    Feb 2009
    Honda accord 1997
    have the engine vacuum checked with the engine idling, when you snap the throttle and at 2000 rpm. it will show exhaust restriction, intake vacuum leak, or intake restriction if any. also, check for egr (exhaust gas recirculation) valve for proper operation
    pinacheck ko sa mekaniko kung anong possibleng sira
    chineck kung nagana ang ang automatic fan ( mga 3 minutes at 2500 rpm) aun gumana ang fan (check)
    radiator cap (hindi pa daw kailangan replace since maganda pa raw ang lapat sa raditor and the spring works fine) (check)
    already clean the radiator (overhaul cleaning) (check)
    ang sabi ng mekaniko is pa check ko raw muna sa expert yung water pump kasi sabi niya baka un daw ang sira. (try this week)
    and papacheck ko na din yung mga hose na may kinalaman sa radiator (try this week)
    regarding sa thermostat? ang alam ko is tinangal na nila ang thermostat neto. may kinalaman kaya ito sa pagoverheat?
    May 2004
    was about to ask it. iirc, me nabasa ko ganyan na mas prone sa overheating ang walang themostat on long drive according to some mechanic. theory nila is mainit na tubig na umiikot sa radiator at din na makuha lumamig kasi walang control ang flow ng tubig. search mo sa internet. for me it make sense
Long drive overheat
