have your radiator hoses checked baka me leaks na. Also, check if the clips attaching the hoses to the radiator and engine block are tight. And check for leaks around the thermostat assembly (connecting the upper radiator hose to the block). And finally check if your car is emitting white smoke sa exhaust baka (hopefully hindi) me leak na cylinder head gasket mo.
