Results 1 to 20 of 34
    Sep 2006
    -parang napansin ko once in w hile pag nagchecheck ako ng 2big sa radaiator may konting putik sa ibabaw. anong cause nito? i dont use any chemicals and just use pure water. balak ko sana pa flush then mag coolant na ako.. ano po kaya possible cause?
    Quote Originally Posted by MasterZerg View Post
    it could be minerals from the water you used or rust. Are you using ground water?
  3. #3
    yup accumilated rust.. kung may time ka, pa- top and bottom overhaul mo yang radiator mo (genaral radiator overhaul)
    depende sa size, 900 to 1500 lang yun... kaysa naman maging cause pa yan ng overheat mo....which can lead to bent cylinder head...
    Sep 2006
    sandali lang po ba mag pa overhaul ng radiator? may nabasa rin akosa old threads na pag pwede tangalin ang drain plug ng radiator tapos lagyan ng host ung ibabaw tapos hintayin na luminis ung lumalabas na tubig is it effective din?
    Sep 2004
    Putik? Kulay Milo? Naghahalo na rin ba yung tubig at langis sa loob ng radiator at reserve tank, pa-check mo na rin yung headgasket. Baka may tama na.
    Pa-flush at pa-overhaul mo na rin mo na rin yung rad mo para sure. Mura lang naman, P450 lang ang top overhaul.
    But it might not be enough to remove the rust that have accumulated at the bottom of your radiator. Think of mud that has time to thicken over time. A simple hose with running water will not be enough to remove it.
    Rust might also be clogging the small passages of your radiator fins so an overhaul would be needed to clear them of these rust deposits.
    Sep 2006
    mga anong range ang price ng overhaul ng radiator?honda esi po ako... ung maliit lang ang radiator single row lang ata
    Try mo pa overhaul ang radiator mo, saan ba ang loc mo kasi sa cavite city rad overhaul 350petot only, incl rem/installation ng radiator, tanggal cover taas at ibaba, sundot lahat ng water lines (alis bara). man hours 3.
    sandali lang magpa overhaul mahihintay mo, then use coolant.
    Aug 2005
    sir kahit anong radiator cleaning di mawawala yan, i've experienced that before. Pag ganyan me problem na Cylinder head gasket, naghahalo na langis at tubig/coolant kaya nagkakaroon ng sediments. although kahit di kayo nago-overheat me tama na ng konti head, kaya yung sakin nung nagpalit kami cylinder head, pinalinis ko na rin ung dinadaanan ng tubig thru engine, then palit upper/lower hoses, overhaul radiator and palit reservoir din para sure.
    upto now wala na yung parang putik sa radiator, prestone coolant gamit ko, yung wala ng halong tubig, pure coolant lang.
    Aug 2007
    Quote Originally Posted by mikejohnny View Post
    Ano yung pure coolant? di ba dapat may halo water kasi masama daw pag pure cooolant?
    Jun 2006
    baka pre-mixed coolant
    Nov 2003
    prestone is pure... but it shouldn't be used like that.
    Oct 2007
    sir same tayo ng experience, dati ganyan din yun radiator ko, di na ako nagpalinis ng radiator ko meron nag-recommend sa akin na gumamit ng coolant, then i-flush ko daw after 1000-km, then coolant ulit, hanggang nawala na yun kalawang nya.
    Oct 2007
    Remember your chemistry. Water is the universal solvent.
    In theory the water that you put in your engine will dissolve your engine.
    That is why you need additives to your water to protect your engine
    and also to improve the qualities of water as a conductor of heat
    for your engine.
    solved this problem of mine.
    i had my rad lav'ra'moned
RADIATOR (may putik sa loob)
