for me, kung sobrang dumi na/kalawang, have your radiator overhaul.... then bago final, put cooling system flush run engine and re-flush with running water until all the acid comes out... use distilled water next time..
don't use turco... you won't be able to get it into the engine din naman since it is so thick.
clarify muna though what you see... may halong oil ba?
bosing,
san sa paranaque ang jp wheels? ang autotechnika? been trying to find a shop that has a lav'ra'mon machine for radiator and engine cooling system flushing.
when i used to own an 82 lancer box-type, had it cleaned in a radiator shop between edsa and libertad, and changed the radiator from a 2-column to a 3-column. not sure kung open pa sila.
paki pm ako sa tibo_3rd*yahoo.com.
thanks.
sir kahit anong radiator cleaning di mawawala yan, i've experienced that before. Pag ganyan me problem na Cylinder head gasket, naghahalo na langis at tubig/coolant kaya nagkakaroon ng sediments. although kahit di kayo nago-overheat me tama na ng konti head, kaya yung sakin nung nagpalit kami cylinder head, pinalinis ko na rin ung dinadaanan ng tubig thru engine, then palit upper/lower hoses, overhaul radiator and palit reservoir din para sure.
upto now wala na yung parang putik sa radiator, prestone coolant gamit ko, yung wala ng halong tubig, pure coolant lang.
Remember your chemistry. Water is the universal solvent.
In theory the water that you put in your engine will dissolve your engine.
That is why you need additives to your water to protect your engine
and also to improve the qualities of water as a conductor of heat
for your engine.
Meron nabibili sa Handyman, pang flushing sa cooling system, just follow the instruction on the can. I tried it already and i'm satisfied.
