Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
    Jul 2017
    #41
    if the condensation is inside the car (for cars without aircon), anti-fogging wipes or a homemade brew of very weak soap solution, on the inside, works.
    for outside condensation, adding a little bit of soap on the windshield cleaner liquid cannister, and spraying it on the windshield at intervals, may work.
    thanks doc. will try it.
    I wonder why my windshield cleaner is only distilled water.
    Sent from my RNE-L22 using Tapatalk
    #42
    Quote Originally Posted by KcireReaver View Post
    mine is tap water.
    Mar 2004
    #43
    actually sir I usually put the temperature to the highest at first but when the temperature is cool enough I twick the knob again. Linalagay ko nalang sa gitna para di masyadong malamig or maybe lower mark.
    That's really not how you use the temperature knob ... set it once at a comfortable level ... Car doesn't get cooler by setting the temperature lower than necessary ... If cabin temp is 29C, you get same cooling effect whether you set temp to 18C or 25C ...
    mine is tap water.
    You risk clogging the nozzles and hoses ... Best to used distilled water ...
    Mar 2004
    #44
    May kinalaman kaya ung tint nya? ung family car namin hindi nman ganito kasi nver had an experience about this. ung tint nya parang visor lang lasi compared to my car na full tint.Sent from my RNE-L22 using Tapatalk
    It's possible that the windshield vents are stuck at open ...
    Aug 2018
    #45
    Quote Originally Posted by SidCoronel View Post
    Toothpaste is a very good cleanser... of teeth ✌️
    Seriously, it will clean your windshield... But is difficult to rub off
    An ammonia based glass cleaner is best, both as a cleaner and ease of use.
    Any suggestions sir for an ammonia based cleaner? gagana din ba yun sa mga rain marks sa windshield?
    #46
    mukhang hard water mark stains na yan. tipong kahit nadaanan na ng wiper, parang malabo parin ..
    elevo watermark remover (or other brands basta matapang) lang yan for the outside, then make sure din na malinis yung loob ng windshield.
    minsan kasi pagka car wash mo, di mo na makikita yung old stains, pero andun yun sa windshield parin. madalas ito mangyari sa mga walang garage, and nauulanan then naarawan yung auto.
    Jul 2017
    #47
    then im gonna be needing temperature gauge. the problem is I dont know the right settings for the comfortable level[emoji848].
    Can you share how you set manual ac? tia
    Jul 2017
    #48
    what are these windshield vents and where can I find it?
    Jul 2017
    #49
    this is also true saka mo lang mapapansin pag gabi at pag nasa loob ka ng cabin
    Mar 2004
    #50
    Check if there's air coming out from the end of the dashboard, where it meets the windshield ...
Help. Cloudy Windshield
