Results 1 to 10 of 135
October 2nd, 2007 04:23 PM #1
It depends on the car. You could make a new thread about it. I'm just familiar with my type of engine for my w123 300D that has a block drainage for the coolant. Maybe others have it, maybe not. In case you have one in your car it's good to have it drained there.
Just don't go about removing nuts and bolts...
- Feb 2006
- 771
October 4th, 2007 01:36 PM #2for example ,do i mix the 50% coolant and 50% distilled water on another container and mixing it first OR do i add the 50%distilled water first on the radiator and i add the 50%coolant on top of it?tska mga sir any idea kung ilang liters ang radiator ng Galant 7G?
tska when draining the radiator any tips to look out in doing so?recommended b n tangalin and palinis muna radiator before filling it with the new mixture?any idea if how much?(2nd hand kc kya just want to make sure )
any ideas about this mga sir?
October 4th, 2007 01:52 PM #3
just add coolant first then distilled water, both will be mixed inside after you've run the engine..
- Feb 2006
- 771
October 5th, 2007 12:06 AM #4salamat po sir BlueBimmer,
follow up lang po any idea kung me nakakalam kung ilan liters ang laman ng Galant 97?
dami salamat po uli
BANNED BANNED BANNED
- Aug 2007
- 999
October 5th, 2007 12:50 AM #5Bakit advise sa akin nung isang mechanico eh mas maganda daw wag na ako magcoolant?
October 5th, 2007 01:07 AM #6
1. Unless your car is aircooled like old school VW's or Porsches, you will need coolant to increase the boiling point and have a higher margin of safety.
2. Find a new mechanic.
3. He probably said that so your car will not last as long and you will take it to him.
That's why these forums exist so people will know better and not just rely blindly on others' advice, mechanic man or hindi. Mechanic ba talaga (with certification, license, etc) or no real way to authenticate him?Last edited by mbeige; October 5th, 2007 at 01:10 AM.
- Aug 2007
- 999
October 5th, 2007 06:10 AM #7Thanks for the reply. Nagsisimula pa lang ako matuto pag dating sa car.
Matino naman yung mechanico. Sya yung nagpalit ng timing belt ko a year ago. Marami din nagpapagawa dun sa talyer and ang laki ng talyer.
Never pa ako gumamit ng coolant sa car ko. Puro tubig talaga. Never pa napalitan yung Water Pump.(hindi ko sinabay sa pag palit ng timing belt kasi gusto makita kung aabot pa sa sunod na timing belt change.)
Mga 89,000 kms na natakbo na car sa 10 years. Honda Civic VTI
Pero tataka ako dun sa Lancer GLXI 97 namin na naka-coolant. Mas mababa pa kms kaysa car ko pero palit water pump na agad nung dumating sa 50,000kms.
Bakit ganun yun nangyari?
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
