Page 9 of 14 FirstFirst ... 5678910111213 ... LastLast
Results 161 to 180 of 273
    #161
    Quote Originally Posted by Joshh View Post
    Yup 3 months warranty po. Mga magkano kaya aabutin po yun kung sa iba ko pinagawa?
    Name the shop, para ala na maluko. Back job muna mo sa kanila, 3 months pa pala issue warranty sa iyo. Pinagawa mo sa kanila para malaman at maayos yung problema ng A/C mo, bakit kamo ganun may problema pa rin.
    Check up and estimate of your A/C system, is free.
    Usually basic cleaning, (evaporator cleaning plus charge freon), nag range ng mga P1,200 - P1,500.
    Any additional job work done, usually their basic charge range from P300 to P350. Example, change compressor, change receiver-drier, change condenser, evaporator at iba pa. Pero minsan, it comes in the package na rin, kaya kahit ipasabay mo na palitan yung ibang part, isang singil lang ng labor.
    Starmobile Up+
    #162
    Some cars have only one fan.
    Yup. Some of those cars got one fan, with no aircon installed. Like if I order a car in a Toyota salesman, give me the most cheapest variant of your new model Vios. No radio, no aircon, give me steel wheels, not mags, carburated type not efi, give me fabric seats not leather, no foglamps. Coz, I intend to upgrade it my way, my style.
    Starmobile Up+
    Jun 2011
    #163
    Quote Originally Posted by sotel View Post
    Bagong palit lang din po pala drier sir.. Tapos Pag buhusan ko ng tubig ng matagal OK na uli pati yung lamig niya
    Sent from my Lenovo A536 using Tsikot Forums mobile app
    High pressure.. Dual condenser...? Check the location of your condenser be sure it doesn't suck hot air coming from the engine. - or the condenser itself..
    Jun 2011
    #164
    Quote Originally Posted by rodetor View Post
    Single condenser lang po. Ang Pinalitan ng brand ne
    w po, ay ang stock a/c compressor at air drier (with sight glass and lo/hi pressure switch). Ang di pa napapalitan at still factory stock, ay ang condenser at eveporator. Wala kasi ako thermometer, kaya di ko masukat ang temp inside ng cabin ng car namin.
    Starmobile Up+
    Problema mo yung gumagawa sir... PalitAn mo yung gumagawa, I'm sure gaganda reading at lalamig Aircon mo sir...
    Jun 2011
    #165
    Ano reading high side and low side--?
    Can you show a picture? The Location of your condenser fan..
    Starmobile Up+
    Yup one fan with aircon.
    #167
    Yup. Right now, I am just scouting in our area, bagamat duon sa una kong pinagawaan, ok na sana eh. Maayos mabilis naman naisagawa ang pagkabit palit ng compressor. Ok, walang leak. Ngunit di nila na-meet ang expectation ko. Yung proseso ng cleaning my evaporator, pagkauwi ko, tsek ko yung housing ng blower fan at evaporator, may hibla pa nang dumi sa inlet vents, katulad ba ng hibla na nakikita sa marumi na blades ng electric fan. Tapos, yung before pag-charge ng freon, bumilang lang yata ng 20 seconds sa pag vacuum pump sa a/c system, sabay tanggal ng pump at tsaka nag charge ng freon. Di muna inantay mag stable ang pressure ng low side, binaklas na freon cylinder. Assement ko, I would not highly recommend them.
    Starmobile Up+
    Jul 2016
    #168
    Mga sir ask ko lng kung napapaayos ba ang compressor clutch or i need to replace the whole compressor..salamat
    Sent from my SM-G355H using Tsikot Forums mobile app
    #169
    magtatanong na din ako.
    nagagawa ba yung blower fan ng Altis 10.5G? yung sa akin kasi medyo maingay (parang may dumi sa loob), pero pag binuksan mo, malinis....and minsan di tumatakbo unless pukpukin mo yung ilalim ng fan.... pag bagong pukpok, nawawala ang tunog, pero pagtagal tagal, lumalakas ang tunog, tapos mag stuck up ulit. i am suspecting the fan motor or the carbon brush, pero nung tinitignan ko yung blower mismo, parang di nabubuksan yung assembly.
    ang mahal ng bago. 6.5k brand new denso original.
    salamat na din sa mga sasagot.
    Jul 2016
    #170
    Mga sir tanong ko na den kng anng model ng compressor ng nissan x-trail 2005 model..
    #171
    Quote Originally Posted by Twenty1Zero7 View Post
    depends on the compressor type... some compressors now are clutchless and since clutchless sya, wala kang papalitang clutch.
    Jul 2016
    #172
    Quote Originally Posted by 1D4LV View Post
    Sir wala po kung idea sa compressor ng sasakyan ko kung clutchless..nissan xtrail 2005 ang sasakyan ko..sir clutchless po ba ang compressor ko..salamat
    #173
    Napapaayos yan clutch ng compressor. Yan ang papalitan sa a/c compressor.
    Starmobile Up+
    #174
    Di nadi-disassemble po iyan for repair, replacing its carbon brush. Palit buo talaga po yun motor para sa fan. Mahal nga lang po talaga. Same with the radiator motor.
    Starmobile Up+
    Jul 2016
    #175
    Starmobile Up+
    Sir my idea ba kayo kung magkano magpaayos ng clutch..nissan xtrail 2005 ang sasakyan ko..salamat sir
    #176
    No idea ako how much would cost it on your vehicle. Better, magpa estimate ka na lang sa mga a/c shops.
    Starmobile Up+
    #177
    when i had my non-nissan clutch replaced a few years ago, i remember 2500 bucks hecho derecho.
    #178
    may clutch pa ata yan bro..... try mo din to visit an AC shop. kung may clutch pwede paayos.
    Starmobile Up+
    ah ok..... so tama hinala ko...... ty bro.
    Aug 2013
    #179
    tanong lang mga sir/madam.
    umiingay na kasi yung AC compressor ng kaibigan ko (1994 Honda Accord), ano kaya possible cause nun?
    Magnetic clutch? AC compressor bearing? o palit compressor na?
    malamig pa siya ang problema lang, maingay kapag nag engage si AC compressor.
    #180
    Quote Originally Posted by innova2013 View Post
    Usually kapag naingay every time mag-engage ang magnetic clutch ng A/C compressor, kadalasan bearing(outer) po. Hindi naman po ba nababa ang RPM kapag mag-engage clutch ng A/C?
    Starmobile Up+
Car Aircon Problem
