Page 7 of 14 FirstFirst ... 34567891011 ... LastLast
Results 121 to 140 of 273
    Sep 2012
    #121
    Some pointers na natutunan ko sa Ceejays
    Importance of having a shroud sa area ng condenser fan. Lagyan pag nawawala kahit yung foam type lang para concentrated ang airflow sa condenser... and you also need to check kung malakas pa buga ng condenser fan mo
    Kapag nagpalit ka ng filter drier, it is recommended na magpalit na din ng expansion valve as precautionary measure. May chance kasi na yung dessicant na laman ng drier is bumara sa expansion valve.
    Invest in a thermometer... check mo temperature na lumalabas sa blower mo. Recommended is 10 degrees Celsius and below ang reading... kapag 12 degrees and up hilaw yan.
    Importance of checking your tint kung maganda pa heat rejection specially during hot months...
    Sent from my Asus ZenFone 2 using Tapatalk
    #122
    Quote Originally Posted by ivo3 View Post
    thanks mga papsie.. problem solve.. replaced compressor, 70/290-300(low-high reading) ata..wala na talaga bumigay na.. stock compressor pa yun considering its 98 model 17 years old hahaha, palit compressor nissan parin, super lamig nanaman
    Tama ba? 70 psi ang Low at 290-300 psi ang High readings ng mga pressure ng sa iyo.
    Starmobile Up+
    Jun 2008
    #123
    Quote Originally Posted by rodetor View Post
    Starmobile Up+
    290-300 psi high side? 134a or R12 refrigerant?
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    #124
    I was asking ivo3. Kung yung ang pressure na nai-karga sa kanya, when he install a new compressor.
    Starmobile Up+
    Jun 2011
    #125
    Starmobile Up+
    High pressure na yan.. High side should read only 150psi up to 240psi
    Low side should be between 25-40psi--
    #126
    Paano po sir? Kagaya ng sa akin, ang reading ng low line side, ay 35 to 45 psi. Ok lang kaya iyon? Kung hindi ko pa ipilit mahingi makita sa pinagawan ko, hindi ko rin maaalaman kung ilan ang pressure ng freon na nai-charge sa a/c system ng car namin. Kapapalit ko pa lang ng brand new compressor.
    Starmobile Up+
    #127
    Sabi ko pa naman sa a/c technician kung pwede ko ba malaman, kung sapat ang karga o kulang ng freon sa a/c system ng car ko. Ang kinabit yung low pressure gauge lang, di pa kinabit ang gauge para sa high. Watching the gauge, while the pressure reach 45psi, the a/c compressor automatically engage. At that point, while the compressor is running or activated, it slowly decreases its pressure until it reaches 35 psi, and it disengage the compressor from running.
    Starmobile Up+
    Jun 2008
    #128
    Normal na mag disengage ang compressor kasi low pressure na. Hindi dapat bumaba yan sa cut-off pressure kung di pa malamig sa loob ng cabin.
    Jun 2008
    #129
    Dapat pirme ang about 35 psi low side & 150-200 psi sa high side with compressor running till aabutin ang cabin set temperature. Hindi taas baba, cut-in/cut-out ang compressor. Stand-in pressure dapat nasa 100-110 psi, yan ang pressure both low & high side at least 30mins after AC off. Pag di nakaka abot ang low side the most cause ay bara or defect ang expansion valve or filter.
    Jun 2011
    #130
    Put an Aircon thermometer-- kung NASA max ang thermostat mo it should reach 0-5degrees... Kung above 8 above hilaw yan..
    Starmobile Up+
    Yung reading mo is I presume dual condenser and dual Aircon-- kung single condenser and Aircon nasa weak side yung Aircon mo..you'll probably need to do internal cleaning of your condenser or replaced it with a Bnew one-- or check you aux fan first..
    Get an Aircon thermometer-- dapat between 0-5 degrees ang temp. Ng Aircon mo.. Kung yung 18 year old van ko-- nakaka zero degrees-- dapat yung car mo would yield similar results
    Jun 2011
    #131
    Quote Originally Posted by weisshorn View Post
    Pwede din ️Yun kung sobrang Taas ng setting ng thermostat nya.. Hindi pa lumalamig na automatic na..
    I think he just needs to adjust his Aircon thermostat...
    #132
    Single condenser lang po. Ang Pinalitan ng brand new po, ay ang stock a/c compressor at air drier (with sight glass and lo/hi pressure switch). Ang di pa napapalitan at still factory stock, ay ang condenser at eveporator. Wala kasi ako thermometer, kaya di ko masukat ang temp inside ng cabin ng car namin.
    Starmobile Up+
    #133
    Today as I warm up the engine, and observing my aircon. Minsan twing mag-on ang aircon, minsan may makita bubbles, minsan naman wala, sa sight glass ng air drier. Normal ba yun?
    Starmobile Up+
    Jun 2016
    #134
    Guys, pinalitan yung Magnetic Clutch Assembly ng compressor. Bumigay na kasi bigla na lang ayaw umandar nung compressor. Normal ba na maingay talaga yun sa simula? Gamitin lang daw ng gamitin bago pa kasi.
    #135
    Pinalitan na pala magnetic clutch, sana pinalitan na rin ang bearing. Ang bearing nagpapa-ingay at hindi ang magnetic clutch.
    Starmobile Up+
    Feb 2012
    #136
    Mga sir Anu pa po kaya sira Pag nag hi pressure pa din kahit napalitan KO na aux fan? Ng mas malakas? Yung pangalawang condenser lng naman po ung halos nakaka Paso Pag hinawakan pero yung isa Hindi naman po?
    Sent from my Lenovo A536 using Tsikot Forums mobile app
    #137
    Quote Originally Posted by sotel View Post
    barado.
    puedeng ang drier.. puedeng kinakalawang ang tubing..
    puedeng... may duming bumabara.
    i would not have replaced my aux fan just yet, unless that aux fan had already proved defective.
    Feb 2012
    #138
    Bagong palit lang din po pala drier sir.. Tapos Pag buhusan ko ng tubig ng matagal OK na uli pati yung lamig niya
    Jun 2016
    #139
    Starmobile Up+
    Buong assembly na pinalitan, kasama na po bearing dun. Kelangan daw gamitin lang para kuminis yung clutch, sa una maingay pero maya maya humihina na. Pero kanina ginamit ko humihina na ingay. Ganito ba talaga pag bago?
    #140
    Quote Originally Posted by xofpeed View Post
    Buong assembly na pala ng magnetic clutch pinalitan. Hindi na rin dapat maingay yan, kung pati bearing pinalitan na.
    Starmobile Up+
Car Aircon Problem
