Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
    Aug 2005
    #21
    Quote Originally Posted by erick_214 View Post
    Hi guys,
    Since napag-uusapan ang pag-lower ng temperature...
    OK ba yung mga aftermarket na thermostat na nakalagay ay opening temperature is 70C? Matibay kaya ang mga ito? Tsaka yung mga radiator caps na 1.3 bars mas maganda bang gamitin yun kaysa sa OEM radiator caps? Any pros and cons?
    TnX...
    1) Having the thermostat open sooner doesn't necessarily do anything more for you unless you're tuning your car and you would like to keep your thermostat wide open for longer periods of time. This will increase your warm up time and fuel consumption as well.
    2) The 1.3 bar cap likewise only raises your boiling point insignificantly at the expense of raising the pressure in your cooling loop causing your hoses and seals to prematurely fail.
    Aug 2005
    #22
    Quote Originally Posted by radz15 View Post
    Guys ask ko lang. 40k na yung takbo ng 2011 mitsubishi adventure ko. nalagay sa manual palit na ng coolant pag 40k na. nung pina check ko ok pa daw yung coolant ko. puno pa yung sa reserved tas nung binuksan ko yung sa radiator puno din at kulay green pa.. Tingin nyo palitan ko na ba dahil yun ang nakalagay sa manual or di muna kc ok pa naman sya? thanks!
    That's a lot of miles for a 2011 car. It may help changing sooner.
Best and effective radiator coolant
