Results 821 to 830 of 1163
- Sep 2009
- 25
October 7th, 2009 04:10 PM #821
- Sep 2006
- 14
October 9th, 2009 02:16 PM #822Tanung lang po kung narerepair pa ni mang mario yung oil leak sa compressor?
at sa mga nagpapalit na ng evaporator para sa fx magkano po ang inaabot sa price at labor kay mang mario?
- Oct 2007
- 10
October 14th, 2009 04:42 PM #823
October 21st, 2009 08:10 PM #824
Naku Bro! Mukhang pareho tayo ng problema. Nabaha ba yang oto mo?
Yung sakin kasi umaandar or bumubuga din ng hangin pero walang lamig.
Vios 08 nga pala kotse ko. Ang sabi nung aircon specialist malamang yung aircon or computer module yung sira.
Malaking gastos to pag nagkataon kasi mahal yun!
- Sep 2009
- 46
October 21st, 2009 09:09 PM #825hello, mga tsikoteers, nabaha rin ang car ko na honda crv, my problem with my a/c is pag naka on ang ignition switch, kusa itong umaandar, even naka off ang controls ng a/c. Tumawag na ako sa Honda service center pero they have to schedule it next month pa, sa dami daw ng nagpapagawa sa kanila. Any insights on what is the problem??? thank you
- 34
October 21st, 2009 09:32 PM #826
- 34
October 21st, 2009 09:50 PM #827
- Nov 2009
- 7
November 5th, 2009 02:55 PM #828I'm new here sa tsikot..im drivin a 96 bighorn, obviously subic..im having aircon problems, typical aircon problems ng subic na suv, mahina ung buga..parang blower ever since i was driving it..daming nagsusuggest to install an overhead aircon, or palitan ung evaporator, worst case benta ko ndaw..gift kc ng erpat ko to kaya di ko mabenta ska ok cia, saved my life nung Ondoy, car ko lng nakatawid sa balintawak nun vs pick ups and other SUV's..and overhead ac or evaporator, aabutin daw ako ng 30-40k..WTF?! baka po may alam kaung mas murang solution..reasonably priced option po sana..
..marami pong salamat..
- Jul 2008
- 7
November 6th, 2009 07:17 AM #829My problem is exactly the same as jacky honta and my ford ranger was also submerged in flood water. I already cleaned out all of the aircon parts and the mechanical side of the aircon system is already working fine. However, it is the electrical side of the system that is at fault. When I turn on the ignition the coil side of the compressor relay has a reading of 12 volts so therefore the relay will be switched on and the magnetic clutch of the compressor will be engaged and activate the compressor. This incident happens even though the thermostat switch, A/C switch, Fan switch and A/C motor are all disconnected.
I know that the easiest solution is to rewire it but I also want to know what cause the problem in the first place because it might affect other system in the car
- 34
Thread was made nung 2018 pa po sir.
