Results 811 to 820 of 1163
- Feb 2005
- 51
September 9th, 2009 11:17 AM #811Tanong ko lang po kung may nakapalinis na ng dual aircon kay Mang Mario. Magkano po singil sa inyo for parts and service.
Thank you
September 14th, 2009 11:39 AM #812
help po! pumapasok kasi yung usok galing sa labas pag naka-on ang AC. ayon sa mga nabasa ko ang cause daw nito ay loose na yung foam seal sa vent flaps.mga magkano magagastos para maayos to?
September 16th, 2009 02:49 PM #813
Actually, wala kang gagastusin dyan... if you just had it serviced. Kasi baka nagkamali lang ng pagbalik sa mga foam yung technician. At kung kakilala mo na yung mga tao sa AC shop mo, bigyan mo na lang ng tip na pang-meryenda. It's easy for them to re-position the foam or feed more foams to seal the vent.
Last edited by jjmd3_787; September 16th, 2009 at 02:51 PM. Reason: tao lang po ...
September 16th, 2009 02:55 PM #814
I just had my Honda's AC cleaned this morning. 8am na nga ako nagpunta duon and as expected, punuhan agad. I was just lucky na yung 1 customer ay wiring lang ang problema kaya nakasingit agad ako.
Mas magalang na ngayon ang mga techs nila, mas mabilis na ang serbisyo, at ganun pa rin ang price. Aside from being a satisfied customer, you can make friends with the other customers.
Last edited by jjmd3_787; September 16th, 2009 at 02:56 PM. Reason: tao lang po ...
September 17th, 2009 12:36 PM #815
Di pa kasi to naseservice since I acquired it last april. Naginquire ako sa isang aircon repair shop. ang advise nila is isabay ko na lang daw sa cleaning kasi ibababa din daw yung mga aircon system. 1000 pesos ang cleaning. kelangan ba talaga ibaba yung aircon system?
September 22nd, 2009 05:57 AM #816
wow! nung una kong nakita ung thread about mang mario na-impress ako at sabi ko dadayuhin ko to para macheck ung AC ko dahil nagyeyelo sya pag long driving... ndi na kasi natigil ung compressor ko.. ndi na nag auautomatic... feeling ko sira lang ung sensor nya kasi nagana padin naman ung thermostat ko e... pero kung may alam kayo sa sira nung kagaya ng scenario nung sakin sa mga yoda ng AC paalam nyo po sakin... maraming salamat! civic VTi 99 pala ung sakin na sabi nila sakit daw talaga un ng civic? not sure... noob ako sa AC system e...
and for aceaceace thanks for sharing your experience with mang mario's shop and thanks for giving the info about AVES... If I may ask alam mo po ba phone number nila? para makapagtanong ako over the phone and alam ko din ung dadalhin kong pera.. salamat!
September 22nd, 2009 05:21 PM #817
agree! experienced this before...medyo kulang sa customer service...got 1 experienced na hindi ko nagustuhan "the moves" ni mang mario ..cguro dahil sikat na siya and marami ng customers...no need to tell the fullstory..basta bottom line, hindi na ako bumalik sa kanila.
- Sep 2009
- 5
September 23rd, 2009 04:31 AM #818Hi po I'm new here at Tsikot....baka Kaya to ni Mang MARIO
This problems happened to my Car all at the same time yesterday ....My car is Honda LXI 01
Please Help po!!!
1. Umaandar and blower ng aircon pero walang lamig (compressor di umaandar)
2. Nawala ang power lock (central) pero ok ang power windows.
3. Palagi naka ilaw handbrake indicator kahit na nakababa na.
What do u think po ang problem?
Napacheck ko na po sa dalawang good Auto Aircon Electrical shop (Rey's Auto Marikina at RAE Auto) di talaga ma solve ang problem. na try na din nila i recta umaandar naman lahat ng unit, walang problema sa compressor etc... sabi nila walang problema sa aircon unit
They;ve check all fuse etc..... ok naman lahat kapag naka direct ay umaandar naman ang aircon. mukhang ang problem daw ay sa ECU or Computer box
After almost 4 hours of analyzing walang nangyari....
They referred me na to bring my Car to Honda Casa kasi nga daw mukhang computer box na ang problem..
Help naman po baka may experience kayo na ganito ang problema na sabay sabay ang sira.....
Thanks...
- Nov 2007
- 164
October 7th, 2009 03:02 PM #819
- Nov 2007
- 164
October 7th, 2009 03:13 PM #820sa mga nagcocoment na mura o mahal service ngayon....bahala n kayo..any body want 2 buy a/c parts..baka mabigla kayo sa pricelist ko...to give u clue ung ipapasok s shop ung starex namin...ichacharge ako ng coil 6500 laminated at 3500 cleaning...dapat discount n un di ba?...eh hinde at hindi pwd n ako gagawa kc marami okong installation nung araw na un...tawag ako sa dati kong mga kasamahan...s kilala nating supplier...ok.. alam nyo ba ang suma ng price?nabigla ako at magmula nun naisip ko na eto na siguro ung tym...* 1 more thing ala kayong mabibiling original parts ngayon...puro lahat replacement..unless kung galing talaga sa casa...example honda esi...pagnagpalit ka ng coil nd n dapat lagyan ng rubbertext or rebunded ung coil..meron ng foam un..dapat sakto s housing nd n ung kumkalog2..
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
