Results 1 to 10 of 34
- Oct 2012
- 25
October 18th, 2012 05:38 PM #1Hi, I have a Mitsubishi Adventure 2000 model. The aircon seems to be not blowing out cool air when the engine is idle or when I am not revving the engine. But when I am revving it up or driving in the expressway the aircon is still not that cold or 'hilaw yung lamig'. Could there be a problem with the compressor?
October 18th, 2012 05:46 PM #2
- Oct 2012
- 25
October 18th, 2012 06:10 PM #3
October 18th, 2012 06:54 PM #4
Was it running ok before you had it clean?
- Oct 2012
- 25
October 18th, 2012 07:06 PM #5
October 18th, 2012 07:34 PM #6
Was the aircon cold after you had it serviced (cleaned and recharged with freon)?
I suggest to check the freon. Maybe you have a slow leak.
- Oct 2012
- 25
October 18th, 2012 08:03 PM #7
October 18th, 2012 08:51 PM #8
Did you check the fans? Baka mahina na ikot or did A/C technician check the compressor Kung ok pa buga?
October 18th, 2012 10:37 PM #9
one of the best indicators of the health of your airconditioning is the manifold gauge. you can get the temperature of the refrigerant inside the system both on the low side and the high side. there is such a thing called the "pressure-temperature chart" this is very self explanatory as long as you see the pressures on the manifold gauge. there is no point in guessing. that's why the gauges were designed, you just have to know how to read them
October 18th, 2012 11:36 PM #10
check nyo po a.c. aux fan baka baliktad ang takbo pabuga.... dapat po ang air papunta sa engine....
pwede din pong masyado mababa thermostat nyo.... try nyo isagad.... yung manual type na thermostat dalawa po ang adjustment nun... yung mismong adjustment at meron din ginagamitan ng screw driver.... alam po ng a.c. techinician yun....
or it could be the compressor.... mahina na ang high side....
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
