Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
    Quote Originally Posted by mitzusu4DJ1 View Post
    kung okey ang charge ng freon and bagong linis din, malamang mahina na compression ng compressor, kung 2000 model pa yan sulit ka na diyan ang price ng compressor Mit-Air pang adventure 10K orig na yon, filter drier linis ng system balik sa dating lamig yan..
    kung mga surplus ba okay lang din?
    Quote Originally Posted by Nelson Cabrega View Post
    depende sa makukuha mo, pero personally, kung pwede naman i repair pa yung compressor mo pa-repair mo na lang.
    nabiktima na ako nyan before (nung medyo engots pa ako sa oto). bumili lang ako ng surplus compressor para dun sa singkit ko... 4k lang ata.... after six months, bumigay din.
    ended up changing to a brand new sanden compressor... hanggang nabenta ko yung sasakyan, malamig pa din yung AC.
    Apr 2009
    I also have an adventure, ganyan din ang naging sakit. hilaw ang lamig kahit umaandar na.
    bale ang culprit sa akin ay barado ang drier and stuck expansion valve. kapag itong dalawa kasi ang culprit, hirap ang compressor magtrabaho.
    malamig na yung akin ngayon, though kapag idle lang mahina ang lamig (I'm quite positive mahina na ang compressor since clutch fan silicone oil has been replaced). but when driving or in short the compressor belt spins fast, malamig ang aircon.
    Quote Originally Posted by p_borj View Post
    bali ang ginawa lang sayo is nilinis yung sa drier pati expansion valve? pero mahina pa din lamig pag nakahinto yung sayo after linisin?
    Feb 2012
    My aircon seems to blowing out hot air instead of cold air.
    Anybody got the same problem as me?
    I called up Aircon Servicing - Singapore, Singapore - Heating, Ventilating & Air Conditioning | Facebook
    to fix the problem for me tomorrow, hope everything will be fine after servicing.
    Flushing and vacuum mo system
    Jun 2011
    sir shadow flushing and vacuum is not enough sir....
    pag pupunta ako sa aircon repair ano sasabihen ko and san may magandang aircon repair na malapit sa marikina?
    Jun 2011
    get a 2nd opinion sir sa ibang shop... then ibalik nyo sa gumawa ask nyo muna bakit hindi malamig? mahirap naman na dictahan natin sila at sila mismo ang may hawak ng van nyo... hindi naman natin alam ang reading etc.... sa reading mo maaring malaman ang problema ng van nyo....
    Hi, I have a Mitsubishi Adventure 2000 model. The aircon seems to be not blowing out cool air when the engine is idle or when I am not revving the engine. But when I am revving it up or driving in the expressway the aircon is still not that cold or 'hilaw yung lamig'. Could there be a problem with the compressor?
    loose compression
    bossing glenn.. saan po kayo nagpapagaw sa congressional? Magaling po ba dun? Yung pajero kasi namin pabalik balik rin sakit ng aircon.. thanks
Aircon problem: doesn't cool when not revving
