Results 1 to 14 of 14
    May 2007
    yung aircon ko kasi napansin ko pag nastuck ako sa traffic tapos mainit ang panahon e humihina yung lamig, then pag nakaarangkada na e lumalamig nanaman. di naman nagooverheat yung makina in fact sobrang baba ng temp nya sa guage, siguro nasa 1/4 or less.
    so nadiskubre ko sira yung thermostat ko (eto yung nagreregulate ng flow ng coolant sa radiator at makina) bali stuck open yung thermostat. so ang assumption ko e since tuloy-tuloy yung circulation ng tubig e pati yung tubig sa loob ng radiator e umiinit na upto the point na naapektuhan na nya yung condenser.
    sa palagay nyo po pag mapalitan ko na yung thermostat e masosolve na ang problem ko? nga pala wala din akong fan nanakainstall sa condenser.
    Feb 2009
    Quote Originally Posted by lnce420 View Post
    your stuck open thermostat did not cause the insufficient cooling of your air conditioning. these are two separate and isolated problems. the insufficient cooling as you described is caused by insuffient refrigerant charge. have your pressures checked.
    May 2007
    *jick sir bakit po pag umaandar yung sasakyan malamig naman na yung aircon kahit mainit na mainit sa labas. i assumed na kaya ganon is because nadidisipate yung init sa condenser since nahahanginan pag umaarangkada na?
    Jan 2010
    there are two possible reasons:
    1. maybe, just maybe, the volume of air your condenser fan is pushing is low and that the ram air is doing the condenser fan's work when the vehicle is in motion;
    2. since the engine is running at higher speed, so is the compressor which compensates for the amount of refrigerant flow
    May 2007
    Quote Originally Posted by barako ba ma View Post
    if that's the case dapat ko pacheck kung kulang ako sa freon?
    what if ok naman ang freon level, ano pa kaya ang possible culprit?
    and hindi ba dapat constant ang takbo ng compressor ke idle man or moving yung engine kasi magvavary lang sha depende sa actual temp na dapat abutin ng a/c?
    Aug 2005
    malamang kulang nga sa freon.
    iyong thermostat, pag naka open lang, mas matagal lang ng konti na maabot ng makina ang operating temp. mas malakas sa gas ang makina pag malamig pa ito. I would recommend na ipaayos na rin ang thermostat.
    Oct 2009
    The A/C Condenser is always located in front of the radiator, so the thermostat valve will not affect the air temp going through the a/c condenser, i agree with jick, it is another problem but will not affect the a/c problem you have.
    There are many possibilities with a less efficient a/c on idle. These are listed below from the simplest to the more complex cause.
    1. Clogged A/C Condenser fins.
    2. Clogged Radiator Fins.
    3. No Shroud on Radiator Fan
    4. Low refigerant
    5. slow or non-working a/c condenser fan (relay, loose fuse, loose connection, carbon brush, bearing)
    6. a/c compressor efficiency (low compression)
    The car interior temperature is regulated by turning on/off the a/c compressor whether you are in idle or high speed, the thermostat switch will turn on or off the compressor.
    Sep 2004
    Check mo din yung rad fan/s mo, baka hindi na maganda yung ikot. If that's the case, either buy a surplus or brand new fan.
    Had the same problem before. Pag umaandar, ok ang aircon, pero pag nakahinto, parang blower lang. Turned out na mabagal na yung andar ng isang rad fan (the other fan was ok). Nung napalitan na, everything was ok.
    Mar 2004
    sir,
    ang rpm ng compressor and dependent sa rpm ng sasakyan. Kaya pag tumatakbo ang sasakyan, tumataas ang rpm ng makina, mataas din ang rpm ng compressor, which means, it is pumping more refirigerant in the system which results in cooling down the vehicle,s cabin.
    Now pag kulang ang refrigerant sa system mo, kahit mabilis ang takbo ng saskyan, hindi masyado malamig ang loob ng sasakyan.
    so, the most probable culprit is your cooling (auxiliary)fan, kasi pag naka idle ka, as you had mentioned, hindi masyado malamig ang buga ng hanign galing sa air con.
    Try mo. habang nakahinto ang sasakyan, lagay mo sa neutral then diinan mo gas pedal to about 2-2.5K rpm. pakiramdamana mo ang buga ng hangin sa aircon kung malamig.
    Ganyan na ganyan ang problema ko. Pupunta ako ngayon ng evangelista para ipaayos yung Fan duon sa may radiator ko.
    Sana umayos sya
    Dec 2009
    guys need help din sa aircon ko kasi pag byahe na malayo sa una malamig yung aircon ko tapos bigla humihina yung labas ng hangin ng aircon pero my lamig mahina lang talaga, tapos ang ginawa ko pinatay ko muna yung aircon after 30mins binuksan ko ulit malamig nanaman then after awhile ganun ulit. ano kaya problem possible kaya na ngyeyelo lang? nagsimule yun ng palitan ko mechanical na yung thermostat ko,...thanks
    May 2007
    Quote Originally Posted by burjegol View Post
    sir,
    sir naobserve ko nga na kahit nakaneutral then dinidiinan ang gas e lumalamig yung buga, at the same time lumalakas din ng kaunti ang hangin na lumalabas sa blower. wala po aux fan yung sasakyan, bali yung fan clutch lang na nakakabit sa waterpump. ano kaya problem?
    Mar 2004
    teka, teka. going back to your original problem. Normally, ganyan talaga ang car aircon pag naka idle. normal iyan na hihina ang lamig dahil mababa ang rpm. pag naka arangkada ka na at mataas na ang rpm mo, lalamig na iyan.
    Again, obserbahan mo. naka idle ka, increase the rpm to 2 -2.5 K rpm, then check mo ang sight glass. kung me bumubula sa sight glass, malamang kulang lang yan sa refrigerant. la relasyon ang water cooling sa engine operasyon ng car air con. they are independent with each other.
    And normally, car aircons usually are being fitted with auxiliary fans. ano ba uri ang ride mo and what year is the model?
    May 2007
    *burjegol sir wala talaga aux fan yung sasakyan, btw 1996 nissan ultra eagle pickup. hinahanap ko din yung sight glass pero di ko makita. familiar naman ako sa sight glass dahil nakikita ko to sa ibang sasakyan namin. pagnagkatime e papacheck ko yung freon then pag hindi freon ang culprit e baka magpakabit nga ako ng aux fan, though nagtataka nga ako na bakit kailangan ko magkabit ng aux fan e samantalang yung designers ng auto e hindi kinabitan. so far hindi ko naman naibabyahe pag traffic yung pickup kaya walang problema heheh.
Aircon problem
