Kung nagkulang ng Freon it would mean na may leak. May problema nga kung ganun![]()
Yung mga bagong car pala hindi na kailangan ng regular cleaning unlike older cars?
I always keep the interior clean. Ako lang naman gumagamit ng auto and the mats don't get dirty that much. I clean my car weekly naman. Sabi nga ibang tao amoy bago pa rin tapos sabi casa may amoy AC ko![]()
Have you noticed / felt a significant change in cooling after the AC filter was replaced?
I have not checked yet. My car is still at the casa. No leak naman daw freon.
Sent from my GT-N7100 using Tapatalk 4 Beta
"Man is least himself when he talks in his own person. Give him a mask, and he will tell you the truth."
Yes. I left it at the casa on Tuesday. I have not decided yet on whether or not to have it cleaned.I am leaning towards checking first if there is a change in the cooling. Hassle lang kasi pabalik balik sa casa.
I am just hesitant to have the cleaning done because I don't want to risk any kalampag or leaks to happen if the dashboard gets baklas.
Isa rin ako sa Hinde nagpapalinis ng kotse regularly. Pag may sira na or significantly nabawasan yun lamig.
Find it sa owners manual walang schedule cleaning ng A/C.
Usually pag nagpalinisn na ako ng A/C palit na lahat condenser under the dash, expansion valve and drier.
Sent from my iPhone using Tapatalk 2
#retzing
Cath yung tower of david magaling din maglinis ng aircon dun, diba suki ka dun? dun ako nagpapalinis dati, 2500 singil nila sakin dati mga 4-5 hrs gagawin. or sarado na ba sila?
Check on the cooling performance first, I'm inclined to believe that there should be improvement. If it satisfies you, then don't have it cleaned just yet. IMHO, your old filter was just way too clogged up na. There are two types of filters available in Toyota AFAIR, one is the ordinary pleated paper type, and the other has a charcoal layer over the pleated paper. This charcoal layer absorbs most of the odors inside the car.
You should change the AC filter periodically, say every 6 months.
Re: kalampag, etc. That is why I recommended you to Toyota casa, you're assured that they will do everything right the first time, and they are well equipped for the job. Plus you have job warranty.
meron sa BLS naglilinis ng aircon system hindi na binabaklas, may parang liquid na pinapasok sort of like a dialysis thing ata
havnt tried it pa
you're talking about labatibathis process is called reverse flushing. there is a solvent under pressure injected into the cooling tubes to flush out contaminants and debris.
btt: the aircon never loses cold air. the air conditioner removes heat from the cabin and dumps it out to the ambient air via the condenser. it acts like a bilge pump of your boat- pumps the water out of the boat and dumping the water back to the ocean
Problema kasi sa linis may possibility madale ang ibang pyesa like mga gasket dahil sa pag baklas and kabit. Posible din na ang mga medyo maninipis na areas sa evaporator mabubutas na lang dahil sa cleaning solution or sa pag-brush ng dumi. Kaya ang sinasabi nila wait for it to die na lang before having it cleaned para at least prepared ka na may sira talaga and di ka magugulat sa presyo![]()
The AC system is under pressure. Parang gulong lang yan. Konting butas lang ubos agad laman.
