Results 11 to 20 of 29
Threaded View
- Nov 2008
- 641
April 23rd, 2015 04:07 PM #1Masters,
Last year I bought a toy car for my wife, its a 2000 Kia Pride GTX AT. So far, all of the mechanicals are running smooth & well. My only problem is the radiator fan which activates only when the temperature is already very high (almost near the overheat mark). There's no problem if you turn On the AC as the radiator fan runs with the condenser fan. I already tried replacing the thermo switch with a replacement and original brand (tried 2 different sets), but to no avail. Radiator has been cleaned too, and i'm currently using distilled water with coolant. By the way, the thermostat valve was also intact and replaced with OEM last December.
Is there a lower temp rated thermo switch I can buy? Your suggestions will be greatly appreciated.
Thank you
it would take a good load of checking, and even then, things could always still remain honestly...
[Tsikot official] Where do you buy used cars?
