Quote Originally Posted by jvnj View Post
Masters,
Last year I bought a toy car for my wife, its a 2000 Kia Pride GTX AT. So far, all of the mechanicals are running smooth & well. My only problem is the radiator fan which activates only when the temperature is already very high (almost near the overheat mark). There's no problem if you turn On the AC as the radiator fan runs with the condenser fan. I already tried replacing the thermo switch with a replacement and original brand (tried 2 different sets), but to no avail. Radiator has been cleaned too, and i'm currently using distilled water with coolant. By the way, the thermostat valve was also intact and replaced with OEM last December.
Is there a lower temp rated thermo switch I can buy? Your suggestions will be greatly appreciated.
Thank you
Baka puwede i-fix na lang radiator fan sa pag-andar nang makina para sabay na. Or direct mo na lang at i-bypass mo na thermo switch.
Masters,
Thank you
