Results 21 to 29 of 29
- 54,207
June 26th, 2016 10:26 AM #21i think you're probably right.
TS, get an auto electrician to set up a separate relay for your aux fans, so that they do not have to share electrical wire with any other appliance. the relay connects to your thermo switch, and the fans connect to the relay.
good luck.
- Apr 2009
- 60
July 26th, 2016 11:30 PM #22Tumataas temp ko near red line kapag crawling yung trraffic. I observed the fans. Yung radiator fan ko mabagal kaysa sa fan ng aircon. Malaki difference ng speed. Ito kaya cause ng high temp during traffic. Nagtanong ako ng radiator motor fan. Motor lang 12k. Sobra mahal. PWEDE ba pa repair yung motor lang. Pwede ba i open yung motor?
- Mar 2014
- 901
July 26th, 2016 11:54 PM #23
- 54,207
July 27th, 2016 12:13 AM #24i don't know... but i have yet to see a fan motor that is fix-able. but what i know is, throw-away sila.
mahal!!! what is your car... BMW?
when my cedia's aux fan died, the shop was selling me oem for 8.5K. namahalan ako. so, i got a generic fan with housing for 900 bucks. we removed the motor from it, and modified the original cedia's fan housing to make the new motor fit. one year later, it was still working fine.
- Jul 2016
- 939
July 27th, 2016 12:26 AM #25Yes, pede mo pa rewind if sunog winding or pa lathe if kayod na armature. Pacheck mo na rin baka brush lang sira. Pasabay mo na papalit bearing, dami nyan sa binondo... Yocks electrical sa cubao the best nyan pero medyo mahal..
Ung mga orig na 2speed fans mahal na talaga. Ala ka ba makita surplus sa banawe o apalit?
Wag ka bibili ng tig 700-900 na sanden aux fans. Fake yun, mababa CFM rating compared sa orig/OEM spec. Dali pa masira, swerte na 1 year tatagal. Sayang lang pera.
Pero if halagang 12k? Mag SPAL fan ka na lang, high performance na. Ang taas ng CFM compared sa stock.. stock is around 800CFM, spal is around 1300CFM. Upgraded ka na.. Maingay nga lang pag umandar parang may bagyo saka need mo ng new wiring/relay/fuse harness.
- Apr 2009
- 60
July 27th, 2016 07:22 AM #26Maraming salamat Janemar.
Pwede ko kaya baklasin tapos rekta ko sa battery para ma test kung mahina talaga ikot. baka kasi multispeed yung fan tapos limited power lang bigay ng system kaya mabagal. baka hindi motor ang may problem.
Subaro forester ride ko. hirap hanap pyesa, mahal pa.
Kung motor talaga paaayos ko na lang sa labas.
Taga laguna ako, dadayo na lang ako sa cubao sa yocks.
Thank you sa fast reply/advise.
Ambo2004
July 27th, 2016 09:41 AM #27
If it's not the motor, it could be a module that controls the fan speed. Try checking also with shops like Reys if they have a motor for your unit, if that is the case. Try checking also online and with part shops that cater to Subbies (Thunder Automotive?).
- 54,207
July 27th, 2016 09:46 AM #28it would be helpful, if we knew what car's aircon we are talking about.
- May 2017
- 34
July 12th, 2017 05:35 PM #29The coolant temperature sensor is used to measure the temperature of the engine coolant of an internal combustion engine. The readings from this sensor are then fed back to the engine control unit (ECU), which uses this data to adjust the fuel injection and ignition timing.
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
