Page 16 of 20 FirstFirst ... 6121314151617181920 LastLast
Results 151 to 160 of 193
    #151
    So sad your SA can't do something to fix it.
    He is good in taking care of his clients pero I guess there is a problem with their technicians. Since special case na yun sakin, dapat tinutukan na. They give me that impression na tutok sila but the results are not consistent. Yung faint noise which I really think comes from the blower was not replaced. If they did a thorough check at ganyan pa rin then this casa must be full of nincompoops
    Dec 2007
    #152
    Yup pero yuns sakin 1 bar lang. And that was from sitting at the garage the whole day.
    Pag hindi ka auto climate, ilang bar AC setting mo with this weather?
    I dunno what the **** kind of testing Toyota did. Bakit 3rd compressor na. MAYBE JUST MAYBE THE FCKING COMPRESSOR IS NOT THE PROBLEM. Ilang araw na ko umiiyak sa inis
    I had good relationship with my SA for 5 yrs before this happened. I actually held back complaining to TMPI because of that.
    Kapag mainit, nag auto ako or around 3 bar sa manual para lumamig kaagad. After a few minutes (around 30 during midday) after iadjust ko na sa 2 or even 1 bar. Sa totoo lang nalulula ako sa full blower blast.
    Dec 2007
    #153
    So hindi pa rin ba sya lumalamig?
    #154
    _Cathy_ I didn't read through all the pages but I think It's time to change casa; preferrably Toyota owned so escalation is quicker. I'll simulate your conditon of outside temp of 30C then set the ac to 24C on auto to note what fan speed it will select then do some screenshots of sensor readings if any on techstream once I get the chance.
    Quote Originally Posted by shok View Post
    I already suggested that in the thread. Hopefully you do some technical testing to satisfy our cravings for results in this thread. Hehehe. Wish I could bring my fluke k-type thermometer but im not in the country. It only takes a few minutes to do these tests.
    Also high and low pressure test but i think thats already too much. Re-vac sana sa labas.
    Apr 2009
    #156
    Yours is a horror story for one who believed so much in a good brand of car but with a bunch of mediocre SA & technicians. Suggestion is you just have to have it diagnosed in an outside reputable & competent aircon shop for 2nd opinion then have it repaired in another Toyota casa with a reliable service technicians. I hope our fellow tsikoteers will recommend the best toyota casa in your area. Im frm the north so i cant recommend you one. Cheers!
    May 2010
    #157
    if everything else fails, bring it to other aircon shop outside casa... Ang casa naman kasi hindi naman aircon ang field of expertise nila... pa check mo Sa EDS car aircon. It happened to me ma din kasi sa Mb ko kung Saan saan Ko na dinalang shop.. Pinalitan Na 2x ang compressor, expansion valve etc. pero ganun pa din... Dinala ko sa eds car aircon, after a series of test... Naayos nila a.c. Ko...
    Saan ung eds?
    Jun 2011
    #158
    Meron sa waze search mo nalang eds car aircon... Quezon City..
    #159
    This is what I see during diagnostics for the AC in GTS.
    Setting is 28C with +2C offset (30C actual setting) but room temp sensor is at 24.75C already.
    Our MID is showing the adjusted ambient temp w/c is showing 31C on the screen and 30.64 in GTS.
    I wonder what your readings look like at the same temp setting for them to say that it's Okay?
    #160
    Toyota said they will send me a copy of their report. It's very frustrating
11th Gen Toyota Altis Aircon Problem
