Results 21 to 30 of 98
- Sep 2011
- 626
June 11th, 2013 11:57 PM #21Also tried tonight the filtered water + joy mix.
Nawala yung gritiness ng wiper kapag nag sweep siya.
Also noticed na mas clear yung glass after, though sa una medyo malabo since nag bubula yung soap.
BTW i noticed na kapag matagal naka on yung washer spray, nag auto off siya?
Same goes for the rear one. Does it heat up that much ba? Pinalitan ko kasi nung umuulan kanina, so I am left to drain the reservoir via washer spray.
June 12th, 2013 02:28 AM #22
Use distilled water to avoid water spots.
Don't use soaps or dishwashing liquid, you will have water spots from the water-soap solution when it evaporates off your windshield, and you risk stripping the wax off your paint.
June 12th, 2013 04:00 AM #23
Sir imho, water spots cannot be caused by filtered/distilled water. If there would be blame it to the elements present in the environment, but at least this soap solution will gently wipe of sticky substance like carbon and oil combined from the air pollutants - just to name a few.
I also disagree of the washer stripping off the wax in the paint as it should be directly aimed at the windshield, unless otherwise you install performance washer that can blast water into your whole car, afaik.
Hth.
Sent from my GT-I9300 using Tapatalk 4 Beta
June 12th, 2013 04:42 AM #25
Chicks, yung akin sakto lang sa windshield i dunno kung swertehan lang. Yung sentra pagmali na ung tama inaadjust ko lang din pati sa car ni erpats.
June 12th, 2013 05:52 AM #26
yung amin both cars hanggang bubong, stock spray lang, yung city hanggang rear windshield pa
June 12th, 2013 06:10 AM #27
June 12th, 2013 06:41 AM #28
Kung merong liquid na hindi ko pwedeng gamitin sa windshield washer ko, yan ay TUBIG
Iba nga gamit ko kapag summer (zero degrees) tapos iba din kapag winter (-45deg).
AFAIK, main ingredient ng WW fluid eh Methanol kaya hindi nagfi freeze kapag winter.
Swerte jan saten pwedeng tubig lang gamitin though i'm not sure if safe sya sa windshield mo kasi alam mo magwa waterspots sya.
Just to be safe, buy a dedicated washer fluid para sa peace of mind.
June 12th, 2013 07:17 AM #29
Ako din I use toyota windshield washer, 1:3 ratio, 3 parts yung distilled water (sa shell 20pesos/liter yung distilled water). With this formula, tumagal ng 4years yung wiper blade. Sa joy kasi parang mabilis tumigas yung wiper blade.
- Jul 2011
- 1,711
June 12th, 2013 08:06 AM #30
Ongoing problem pa din Pala ito even among euro cars ...
Takata Airbag Problems
