Results 1 to 10 of 16
- Nov 2004
- 45
December 16th, 2009 09:02 AM #1Good day ! Just went to Handy man and Ace near my area and unfortunately we I cannot see the elevo glass cleaner and I ended up buying the armor all glass cleaner.
Anyway I also bought a very fine sand paper 2500. I was wondering if I could also use this to clean the wind shield glass.
I have at home -a salt water aquarium and I used these fine sand paper to clean the glass scales and its very effective.
Just wondering If I could use it also.
Thanks in advance.
December 16th, 2009 09:35 AM #2
To be sure get those Elevo winshield cleaner, marami sa Robinson's Do It Yourself Center at sa True Value shops.
Be sure to wet first the glass and body before applying the Elevo liquid medyo harsh yung chemical and use hand gloves.
Di ko lang sure kung ang nakakatanggal ng water marks ay yung appllicator/scrubber pads na parang scotch brite or minimal lang ang effect noong chemical ng ElevoMedyo mahirap din magtanggal ang water marks using Elevo lalo na malaki ang winshield.
Makikita mo na malinis na salamin when you hose it with water, pantay ang dulas ng tubig.
December 16th, 2009 09:10 PM #3
I got curious po. What's on the glass that made you think of using sandpaper? Hope you could post a pic or two. Thanks.
_____________________________________
Jon
My auto detailing experiences:
http://autodetailingexperience.blogspot.com/
December 18th, 2009 11:41 PM #4
just an experience with using sandpaper on windshield. i tried it before. it looked very promising. the problem occurred when i used it at night and headlights were coming my way. there was glare and sabog na sabog. i couldnt see anymore. the sandpaper marks were very visible.
December 19th, 2009 12:08 AM #5
I also use Elevo glass and plastic cleaner and very useful removed the blackish color and safer to use than the sand paper even though its finer it is an abrasive that why
it may leave scrathes .
December 19th, 2009 12:09 AM #6
Actually, all you need are two cups of baking soda and a wet white rag. Strong arms recommended.
January 8th, 2010 01:53 PM #7
i may have posted this already, but my body shop buddy supplied me a good amount of very fine steel wool that i use for glass esp water marks and oversprays. i try not to use too many chemicals, so for general cleaning i use my quick detailer spray which is my wash liquid and water.
- Feb 2009
- 171
January 8th, 2010 04:54 PM #8Question:
Why not use rubbing compund? Wet your windhshield the get a wet rag then put some rubbing compund on it. Rub it to your windshield until satisfied. After, wash your windshield. look and feel to notice the differenceNagawa ko na ito and the results are better compared when using elevo watermark remover. Ive only use 3m rubbing compound that can be bought in sachet.
- 34
January 10th, 2010 08:11 PM #9
BANNED BANNED BANNED
- Feb 2010
- 5
February 3rd, 2010 12:28 PM #10[size=1]Bride [/size][size=1]wedding dress[/size][size=1] is one of the best modifier, it can show us the beautiful curve was dripping try to, but can also be modified under our well, so when the bride to wear for their wedding, they Exhibition emerged in the most beautiful side. So how are we going to choose their own wedding dress then?1, inviting the prospective husband or Jiemei Tao together to help you choose the most suited to their wedding. 2, wear light-colored, removable shoulder strap underwear, to avoid the embarrassment of drop out of underwear. 3, wear light-colored high-heeled shoes. When the girls wear high heels, the body tend to be more upright, more self-confidence, coupled with the effect of wedding will be better. 4, we should set up and the hair, will be more showing your elegant temperament. 5, if you have the wedding before it is concealed want to use the first yarn, and then to choose the head of relatively large yarn to ensure that the length of the first yarn cover down between the chest and lower abdomen.[/size][size=14][size=14][size=1]Source: Sufica [/size][size=1]wedding dress[/size][size=1]yiwu hotel[/size][size=3]Cheap cell phone[/size][size=3] [/size][size=3]wholesale china cell phone[/size][size=10pt][/size][/size][/size]
but toyota outfits their cars with locally manufactured yokohamas. i just follow suit. after many...
Finding the Best Tire for You
