Results 11 to 19 of 19
September 26th, 2015 09:08 AM #11
Guys, would it affect the defogger at the rear windshield if the tint is removed?
September 26th, 2015 12:42 PM #12
- Aug 2012
- 2,767
September 26th, 2015 02:58 PM #13I think it is the opposite. Removal ang mas delikado kaysa installation. Nagpakabit ako ng new tint sa rear windshield dati. Solar Gard Santolan had me sign a waiver for damages to the defogger that may result during removal of old tint. But they will remove the old tint carefully naman. Working pa rin ang defogger after intalling the new tint.
September 26th, 2015 03:16 PM #14
OT
How to check if defogger is still working?
- Aug 2012
- 2,767
September 26th, 2015 05:55 PM #15
- Oct 2009
- 2,271
September 26th, 2015 08:18 PM #16mahirap tanggalin kung mga nasa 3years old na tint mo.may maiiwan.
pero kung mga nasa 1 year palang .bili ka lang ng cutter blade pang cut sa isang gilid para masikwat mo kung baga.tapos hatakin mo na ng dahan dahan hanggang sa matanggal mo.wag ka gagamit ng heat gun at baka masobrahan.delikado pa windshied mo,mababasag yan..
September 26th, 2015 09:54 PM #17
I had experienced with my 1997 civic where the defogger were damaged at some sections after a tint replacement. When it rained and I switched it on, I could see portions of the windshield remained hazy while some portions were clear.
- Dec 2017
- 1,018
March 23rd, 2018 05:00 PM #18I've removed a very old tint on my civic 2000.
I use steam to remove it. Steam softens the tint and dissolve the adhesive making it simple to remove. Even if the adhesive is hard like stone or a century old. Steam will just annihilate it to smithereens.
What I did was to shove a garden hose in the kettle spout and secure it with a duct tape. The hose should be long enough to reach the areas of your windows, especially the rear window. Since I have a portable induction stove, it was easy and safe for me to do this as no flame is involved.
When the water boils in the kettle, hot steam will be coming out of the hose. I use a towel to handle the hose because it so freaking HOT! I directed the hose on the tint and let the steam do it's job to soften the tint and dissolve the adhesive. Maybe, 30 seconds or so, you can start peeling it by using a plastic ruler. Do not set aside the steamer. Attack it as you peel and scrape. If you set aside the steamer, the tint will cool down and it will be harder to remove. As for the rear window with the defogger, no problem. Just attack the tint with the steam and the tint will just slide off. You can use your fingers, but it will be too hot.
An alternative for this is, you can use your iron set at max and place a damp towel on it. Steam will be coming out from this. Then, you can iron the tint with the damp towel and just the same, the tint will slide off like butter. Just make sure to damp your towel in your pail, otherwise it will get dry. However, with this method, it will be difficult reaching the bottom part of the rear window.
Labor cost: 0
Experience needed: None
Time needed: 2 hours
Fun factor: It can get addictive as you peel LOL
Happy Steaming!
- Jan 2017
- 429
March 23rd, 2018 05:42 PM #19On the topic: san maganda/maayos magpainstall ng vkool tint?
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
