Results 1 to 10 of 16
July 27th, 2009 10:55 PM #1
Anybody tried this product yet?
Is it very effective? How effective is it?
Can it be used on side mirrors?
btw..
It costs P350 on BLADE..need feedbacks thanks
sorry for the numerous newbie questions
- May 2006
- 59
August 2nd, 2009 02:41 AM #2hi. i tried using this product and it's good as window cleaner but not as good as water repellant. I guess you need to apply Rain Clear water repellant to maximize the water repelling action of rain clear which I have not tried yet because I can't find one.
August 2nd, 2009 09:00 AM #3
I've tried it. And it's a good product for those times when you need a quick AIO for your windshield and side mirrors.
But... it should be noted that I have used it as a mere maintenance/booster product in between my regular claybar, Glass Scrub, and Rain Clear Gel regimen.
Hope this helps.
August 2nd, 2009 11:12 AM #4
thanks for the feedback guys
clarification, so it's not that effective as a rain repellant but it's good as a glass cleaner?
RAIN CLEAR GEL is still the best for rain repellant?
TIA TIA =)
August 2nd, 2009 11:52 AM #5
To put things into perspective, a comparison of the spray with the gel is not a fair one, as they are of different categories.
Used properly, I would still consider the Glass Cleaner & Rain Repellent Spray as that which leaves some water repellent coating on your windshield - and it performs well IME. In one of my vehicles, i haven't done a Glass Scrub and Rain Clear Gel routine for more than six (6) months now. I've just done a weekly application of the Rain Clear Spray. No water spot problem so far.
August 2nd, 2009 02:23 PM #6
August 2nd, 2009 02:40 PM #7
No judders - my guess is that my prep (clay and Mothers Chrome Polish or Glass Scrub) of the glass helped a lot. You might even find that you won't even use your wipers as often. IME, I still get relatively good visibility during a rain because it just beads up on the windshield.
August 3rd, 2009 12:13 AM #8
What if I don't do the prep? (cause i don't have the budget yet).. Will it still work if I only just clean the glass and then apply the Rain clear spray?
I have an Armorall Auto Glass Cleaner (Spray) too btw..Does it also come in handy when it comes to caring/maintenance of the glass?
edit: BTW may I know po what are the brands of those prep items you use? Just in case lang po pag nakaipon ng konti ma-try naman..
August 3rd, 2009 12:30 AM #9
Back when I was using water repellents (Rain-X) on my windows, I don't use it on my front windshield because it causes my wipers to skip. I just use the product on my other glass surfaces (sides, rear and mirrors).
I don't see the need to use it on the front windshield since the wiper will remove the repellent film after a few minutes of wiper action.
August 3rd, 2009 08:24 AM #10
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
