Results 31 to 40 of 44
- 10,620
May 13th, 2003 02:26 PM #31Originally Posted by GlennSter
anyways turn it off kapag sa busy streets
May 13th, 2003 06:00 PM #32
in driving, if the O/D is set to off while driving on both city and highway, will that trigger higher temp on the engine?
May 13th, 2003 09:24 PM #33
not in the engine... more of higher temperature in your tranny. If you drive long distances often, you might want to have a transmission cooler installed.
May 13th, 2003 09:37 PM #34
okay ba ang O/D off kapag city driving..consider mo na ung traffic and low dirving speed mo..
May 15th, 2003 01:39 AM #35
d ko alam un ahh. .hehehehe
galning nmn ni otep.. hahahaha :mrgreen:
pero bakit ser boybi pag oovertake iooff? :roll:
May 21st, 2003 11:39 PM #36Originally Posted by OTEP
So dalawa pala ang overdrive gears nung MDX ko dati :?:
MDX Gear Ratios:
1st / 2.693
2nd / 1.566
3rd / 1.023
4th / 0.729
5th / 0.531
Nagtatanong lang po 8)
May 22nd, 2003 12:12 AM #37
odell, OFF ang O/D pag gusto mong humatak ang A/T pero di tipid sa gas. Kung gusto mo ng more technical explanation, nasa first page :mrgreen:
OTEP, kaya pala sa tech specs ng car ko nakalagay Manual with O/D then naghahanap ako ng O/D switch. :mrgreen: yun pala, 5th gear yung O/D or may O/D ba?! :mrgreen:
May 22nd, 2003 12:25 AM #38
Macky,
Yep, dalawa ang overdrive gears mo if that is the case. Pero pansin ko lang, most O/D off switches only cancel top gear. Ganun din ba sa MDX?
kiper,
O/D on mo parin. Ako kahit city driving umaabot ng 5th gear. For special circumstances lang ang O/D off. Kaya nga may warning lamp to inform you that it is off.
May 22nd, 2003 12:44 AM #39Originally Posted by OTEP
May 22nd, 2003 01:13 AM #40
Macky, kaya din siguro sa 1990 Integra, may D3 and D4, pang tipid lalo sa gas???
R,1,2,3,D, D3/D4
What vehicle and what's your budget?
