Results 21 to 40 of 44
    #21
    Isa pang application ng O/D off is when your call is full. Mas malakas ang hatak kapag O/D off. Mas malakas din sa gas kapag parating naka O/D off.
    Kung normal driving lang, O/D on.
    Mar 2003
    #22
    can u really feel the difference once the O/D is on or off?
    #23
    Quote Originally Posted by ownertype
    yep :D
    #24
    thanks guys...
    peace!!
    #25
    Quote Originally Posted by ice27
    sa a/t? how do you use it?
    peace!!
    overdrive in A/T is the equivalent to the 5th gear in M/T. It lets the engine rev at a lower rpm while traveling at higher speeds. Its meant to save gas on long distance driving on mostly level roads.
    #26
    Para hindi ka maguluhan, just think of O/D as 4th gear. When you turn it off, hanggang 3rd gear ka lang.
    Just keep that in mind.
    Most 5th gears on manual trannys are overdrives. Their ratio is less than 1.000 kasi. Any gear whose ratio is less than 1.000 is considered an overdrive gear.
    #27
    ang galing talaga magpaliwanag ni sir OTEP! :D8)
    Signature
    #28
    ayun! ayun pala ang maliwanag na paliwanag na OD! galing ni OTEP ah.
    nagtataka lang ako kung bakit may OD3 and OD4 ang 1990 Acura Integra. Bukod sa R,1,2,3,D, may D3 and D4 pa. sobra naman sa over yun :mrgreen:
    #29
    Quote Originally Posted by kimpOy
    tama ka delta bravo, so kapag city driving dapat naka off ka para up to 3rd gear ka lang
    lakas sa gas niyan.....
    ang tingin ko naman sa OD....is mataas ang gearing kapag naka on...so mas mabilis...pero mahina ang torque....
    mas matipid sa gas pag naka on...pero mahina ang batak...
    gets?
    #30
    Sa experience ko normal driving ko OD on. Kung uphill ka dapat OD off para hanggang 3rd gear ka lng at hindi mag gear hunting.
    down hill OD off ako para may engine break..
    #31
    Quote Originally Posted by GlennSter
    gets?
    opps my idea nung city driving yung ma traffic he..he
    anyways turn it off kapag sa busy streets
    #32
    in driving, if the O/D is set to off while driving on both city and highway, will that trigger higher temp on the engine?
    #33
    not in the engine... more of higher temperature in your tranny. If you drive long distances often, you might want to have a transmission cooler installed.
    #34
    okay ba ang O/D off kapag city driving..consider mo na ung traffic and low dirving speed mo..
    #35
    d ko alam un ahh. .hehehehe
    galning nmn ni otep.. hahahaha :mrgreen:
    pero bakit ser boybi pag oovertake iooff? :roll:
    #36
    Quote Originally Posted by OTEP
    So dalawa pala ang overdrive gears nung MDX ko dati :?:
    MDX Gear Ratios:
    1st / 2.693
    2nd / 1.566
    3rd / 1.023
    4th / 0.729
    5th / 0.531
    Nagtatanong lang po 8)
    #37
    odell, OFF ang O/D pag gusto mong humatak ang A/T pero di tipid sa gas. Kung gusto mo ng more technical explanation, nasa first page :mrgreen:
    OTEP, kaya pala sa tech specs ng car ko nakalagay Manual with O/D then naghahanap ako ng O/D switch. :mrgreen: yun pala, 5th gear yung O/D or may O/D ba?! :mrgreen:
    #38
    Macky,
    Yep, dalawa ang overdrive gears mo if that is the case. Pero pansin ko lang, most O/D off switches only cancel top gear. Ganun din ba sa MDX?
    kiper,
    O/D on mo parin. Ako kahit city driving umaabot ng 5th gear. For special circumstances lang ang O/D off. Kaya nga may warning lamp to inform you that it is off.
    #39
    Macky,
    Walang O/D switch sa MDX..... gated gear selection already has D5, D4, D3, 2, and 1..... Siguro kaya ganito ginawa ng Honda para makatipid sa gas mileage. Usually kasi ang complaints dito about midsuze/fullsize SUVs is matakaw sa gas. By having 2 ODs, makakamenos nga naman sila sa gas consumption.
    #40
    Macky, kaya din siguro sa 1990 Integra, may D3 and D4, pang tipid lalo sa gas???
    R,1,2,3,D, D3/D4
What is Overdrive in A/Ts?
