Results 1 to 4 of 4
- Apr 2017
- 15
October 26th, 2020 11:49 AM #1Hi!
I have a Vios 2003 A/T with 165k odo reading on it, however, I am experiencing a very problematic issue with its transmission. Whenever the car is left overnight and I start it in the morning, changing to the forward gears doesn't do anything until I let the car warm up to about 25-30 mins that's just the time the card moves forward. The amount of time depends on how long the car is turned off. When I leave it off for about 2-3 hours it just takes 10 or so minutes. Reverse gear has no problems at all just the forward gears.
I've already change my tranny fluid 2 times and it helped a little. But after a few days, it just goes back to the usual warm up time. I've also let my mechanic clean the oil pan and change the seals on there to no luck. So a transmission repair is indeed needed.
Problem is, there is now transmission repair kits for my car here in my province (Pangasinan). Can you recommend any shops which is available for online transactions?
Thanks in advance!
- May 2019
- 312
November 6th, 2020 05:52 PM #3
keywords to use on facebook: banawe toyota
several results come up and try to filter which accounts have the most followers.
banawe online is one...
- Jun 2005
- 3,774
November 7th, 2020 07:13 PM #4Make sure you are using toyota t-iv tranny fluid. Ganyan yan pag mali fluid.
Worst case replace tranny
Sent from my MI MAX 2 using Tapatalk
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
