Quote Originally Posted by mbeige View Post
First check the easy ones, baka throttle cable lang problema at masyado na malaki ang stretch, sabay weak point ang third gear. Good call on replacing ATF. Did you drain the torque converter too? Usually pag nagpalit ng ATF hindi lahat lalabas, dahil nasa torque converter yung matitira.
Good chance na baka kailangan mo na nga maghanap ng surplus, pero check the easy solutions first baka may na-overlook ka lang.
ok. check ko yung cable.
may paraan ba para ma-check at maayos yung "weak point" na 3rd gear? anu ibig sabhin ba pag weak point???
mukhang na-drain ko kahit yung sa torque converter. ginawa ko, disconnect ko yung isang hose then start engine for 5 sec para maalis yung atf th torque converter.
