Results 1 to 7 of 7
- Sep 2005
- 29
June 21st, 2007 09:45 AM #1A week after I had my clutch repaired, napansin ko na may konting tagas sa transmission so I had the oil seal replaced. After several days, meron na naman. Di naman malaki ang leak pero definitely talagang meron. My questions:
1)Ano kaya ang posible cause na nag leak uli?
2)Kung very minimal lang naman, how long will it take para maubos ang transmission oil and what will be the symptoms/effects on the car?
I hope someone can address this. Thanks very much.
June 21st, 2007 09:48 AM #2
2 oilseal ba napapalitan mo? baka di maganda ang pagkakasalpak..
pero alam mo, most oil seals/rubber gaskets in the market talagang pangit na...yan ang prob namin dito..
- Sep 2005
- 29
June 21st, 2007 09:54 AM #3
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 24th, 2007 02:54 PM #4could be replacement oil seals or that they were not installed correctly.
June 24th, 2007 03:34 PM #5
anong seal ba yung pinalitan? yung rear crank oil seal?
Ganito, observe muna for a few days kung nagbabawas ng langis ang "engine", kung nagbabawas ang problema siguro dun sa rear crank seal.
Kung hindi nagbabawas yung "engine oil" it might be your gear oil leaking. There's another seal sa may tranny (can't remember the part, tripod something) baka kailangan na din palitan.Last edited by artpogi; June 24th, 2007 at 03:42 PM.
Toyota is my choice
- Aug 2005
- 2,063
June 24th, 2007 03:38 PM #6pa underwash ka tapos after 3 days tignan mo ulit. if may tulo pa din oil seal na yan.. dapat orig japan oil seals para mahaba ang buhay ng seal.. pag down transmission sabihin mo palitan lahat ng seals para isang service charge lng yan and no worries .
June 24th, 2007 11:16 PM #7
Evag,
Saan mo nakita yung leak?
Alin oil seal ang pinalitan sa may input shaft ba ng transmission or yung main crankcase oilseal? Inalis ba yung flywheel?Last edited by 4JGtootsie; June 24th, 2007 at 11:18 PM.
Buy adhesive remover or try the Johnson's baby oil approach. See if it works for you.
Removal of Rain Visor and Chrome Door Handle and...
