Results 21 to 30 of 32
Tsikot Member Rank 5
- Nov 2003
- 3,849
- 49
July 25th, 2009 07:21 PM #22Hi Speedyfix,
How many quarts of gear oil is needed for a 93 Lancer GLi (itlog)? Thanks.
- Nov 2003
- 3,849
September 9th, 2009 12:13 PM #24
sorry po sa newbie question ko, sa A/T kasi, may AT Fluid na nilalagay, eh how about sa M/T? Kailangan din ba magpapalit ng transmission fluid? 72k km odo reading sa 02 Adventure M/T Gas. May kailangan bang palagyan? kung meron, i'll try dyan sa speedyfix shaw blvd. How much na rin po sir speedyfix kung kailangan palitan?
- Nov 2003
- 3,849
September 9th, 2009 02:05 PM #25yup, gear oil should be replaced every 40k kms also. you need about 5 quarts for the tranmission and rear differential. price will depend on the type of gear oil you use.
September 9th, 2009 03:24 PM #26
5k? wow, I assume ito na yung pinaka-murang quality of gear oil. Since you said that the price depends on the type of gear oil na ipapalagay ko, mabibigyan niyo po ba ako ng quotation para sa pinaka-top of the line gear oil kung ganitong type ang ipapalagay ko?
Baka pumunta ako diyan sa Shaw Blvd branch next friday sa 18, just need to know the budget needed and kung aabot. Since nakuha namin yung advie nung 2002 December brand new, hindi pa napalitan ang gear oil nito.
Thanks in advance sir speedyfix.
- Nov 2003
- 3,849
September 9th, 2009 04:07 PM #27if you use royal purple max gear it's 800/quart. plus labor for the drain refill. if you use castrol gear oil it is significantly cheaper.
if you need a quote the you can contact the numbers in my sig. or go here: http://speedyfixph.com/estimate.html
September 27th, 2009 05:25 PM #29
- Nov 2003
- 3,849
high idle RPM at engine start
