Results 11 to 12 of 12
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 8th, 2006 02:00 AM #11probably a leak in the master.
but pedal feel should not change with or without a/c
January 10th, 2006 12:55 PM #12
back to topic...
sinubok kong magpalit ng transmission oil. SAE40 as stated in the manual. medyo nabawasan yung hummming noise pero meron pa rin specially when slowing down using engine brake. I also found out na masyado madami naikarga ko the last time I changed the oil in the tranny. medyo maiitim na rin yung oil after more than 25,000 km. sa susunod, differential oil naman.
high idle RPM at engine start
