Page 3 of 3 FirstFirst 123
Results 41 to 60 of 68
    Quote Originally Posted by ejm_110 View Post
    Drain now then flush when you have budget.
    If money is no concern, flush now.
    Same happened to us. Went up to 60k without draining by previous owners. We wanted to flush but hard to find the shop and we no have budget yet at that time. In the end, we just drained. We feel slight to below average improvement in shifting though.
    Our owners manual says to flush every 40k, iirc.
    One shop we went to said that they discourage flushing specially if not flushed for a very long time. As per their experience, after flushing, it became problematic. I read the same thing here/other forums.
    Their advice is to drain and refill every 1 week (forgot for how many weeks, maybe 4-5 times?). They claim that method is something like 'gentle flush'.
    The shop is the one specialized in auto transmission in sucat. Forgot the name.
    What we ended up doing is to drain once. And follow regular schedule or brown color atf. Money is tight. If we have the money, I will do the gentle flush method then regular schedule.
    Goodluck!
    Edit: want to DIY? watch chrisfix on YouTube. You may want to bingewatch that channel. Also AMMO NYC
    Sent from my ONE A2001 using Tapatalk
    flush? paano ang flush? flushing with an additive?
    drain and fill lng nakalagay sa owners manual. wala naman naka lagay na flush..
    Jun 2009
    Dialysis. Kinda synonymous though but technically not.
    Better to check my manual again hehe
    Pag medyo may edad na ang sasakyan annual na ang pagpalit ng atf to be safe. Drain and refill naman so hindi ganun kabigat din.
    Every 80k kms lang ako nag dialysis. So far so good
    when you look into the abyss, the abyss looks into you
    Jun 2009
    Sir may I ask of where you had your dialysis tranny oil change? Long overdue na kasi itong car ko. Thank you sir
    Jun 2005
    Quote Originally Posted by crv99ner View Post
    Servitek. Nasa 1500 labor. Bring your own ATF.
    Exalta banawe 700 labor bring your own ATF din
    Sent from my MI MAX 2 using Tapatalk
    Mga bossing, yung Fortuner 2016 (Dsl 4x2 Automatic Trans) ko ay nakaabot na ng 40,000 km so kanina aside sa change oil, nag-pa drain din ako ng ATF para pailtan. However, yung na drain lang ay nasa 3 liters lang. Ang nasa Toyota Manual/Handbook yung ATF is nasa 9,5 liters. Dahil 3 liters lang na na-drain, 3 liters din ang napalit. Hindi kaya na sayang lang yung new 3 liters na ATF dahil yung karamihan sa natira ay lumang ATF na maitim?
    Jan 2008
    Quote Originally Posted by attyallanlatras View Post
    again, may tamang procedure sa pag drain ng ATF ng toyota transmission na walang dip stick.. watch you tube videos.. dapat nasa tamang temp yung transmission pag drain.
    if i remember, same yung fill plug at drain plug nyan. may parang straw sa loob na mag dictate ng level ng ATF at the right temp. kaya yung nakuha na 3 liters ay malamang dahil mainit yung ATF at nag expand na sya..
    Drain and fill.. is different vs dry fill(9.5L)
    The old fluid should still look red though.
    9.5L might be the total amount of fluid in the whole tranny system. In most drain and refill method for AT trannies, the amount of fluid drained is just about a third of the while liquid content.
    You will need a dialysis method to change the whole content of tranny fluid.
    Normal drain and refill will do if you are changing tranny fluid within short intervals like 40k km. If it is done over a long period, you can do the dialysis method. If you have no dialysis machine, you can do drain and refill in a multiple sessions until you have used up a total volume needed. On your case, maybe 3 drain and refill sessions.
    Finally had an atf filter change kanina along w/ the usual atf change on my civic fd2. Mukhang ok pa naman and walang mga metal shavings na unusual according to the mechanic.
    Ito Pala iyong in-line atf filter nya
    Sent from my RMX3690 using Tsikot Forums mobile app
    Jan 2016
    How many kms na ang FD mo Sir?
    ^ 152k ++ kms na din tinakbo niya bosing
Transmission fluid change - A/T
