Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
    Jun 2008
    #21
    Not sure of this but it says the oil is inside the torque converter, the oil in the sump might not be enough to feed the oil pump to lubricate internal parts. Baka may masira sa transmission.
    Quote Originally Posted by rapidfire_28 View Post
    Question guys.
    Can I start up the engine after I drain the fluid to pump the remaining fluid in the torque converter.
    Because I read an artcle that 50% of the fluid remains in the torque converter?
    TIA
    No, kung ganyan Kabilis wala na sana dialysis system ngayon and Hinde na kailangan open transmission King talagang gusto malabas lahat ng atf
    Question guys.
    TIA
    Pwede pero mga 10 seconds lang dapat.
    #24
    Question guys.
    TIA
    I have not tried but it doesn't sound like a good idea. Better to just do a ATF dialysis, or drain and replace the fluid 2-3 times over the a short period of time.
    Mar 2005
    #25
    Quote Originally Posted by weisshorn View Post
    I think yan yung advantage ng Dialysis machine kasi while hinihigop yung lumang ATF at the same time nag lalagay din ng new ATF sa tranny. Mas less waste kesa Drain/Fill/Drain/Fill method kasi may nahahalo pa din na lumang ATF.
    Jun 2006
    #26
    i switched atf to top1 brand...ampangit, mabilis lumabmaw, nawawala reverse pag mainit.
    I drained the entire atf imcluding the torque converter thru the intercooler line. Cycled thru all the gears and poured 5.5 liters of whiz atf.
    No adverse effect, reverse still retained even in traffic. Gears shifts without any shock,
    Quote Originally Posted by shibby75 View Post
    I would never get top1 hehehe.
    Jul 2011
    #28
    Thanks sa mga nagreply. Yung sa intercooler line ang gusto sana gawin, not sure if may magdadrain if donn ko pinatagas and saka wala ba possibility na mag kabubbles sa loob?
    If ever drain/refill/drain/refill na lang.
AT Tranny Life Expectancy
