Originally Posted by
rion
not all rides use the old kickdown cable. see if there is a cable next to the throttle cable. it is usually wrapped in orange rubber. a small movement of the nut already makes a noticable difference. again, put markings on your original settings so you can return it to original anytime.
are you sure, you can't reach 100 at all? a loosy kickdown cable may take a little longer to reach 100 but it could still go pass it.
at this point, let's solve the a/t problem first.
