Results 1 to 18 of 18
    Mga gurus,
    This has been a bother to me for the past few months, kung minsan (kung hindi ko aalalayan) merong knocking sound (parang tok sound) upon my release of the clutch after shifting gears. Napalitan ko na ang upper and lower cross joints ko. I'm all out of ideas na rin. Your suggestions will be highly appreciated. Thanks.
    Dec 2007
    Quote Originally Posted by mazingerZ View Post
    Mga gurus,
    sir, anong kotse po ito? anywayz, have you checked your Shift Linkages (if its FWD) or Transmission Mounts? also, if the car is RWD, check your Driveshaft (or Propeller Shaft) Center Bearings and U-Joints (Yoke.. etc.)
    aite, peace.
    zuk vit sir. part time 4wd. thanks for the prompt reply.
    Feb 2005
    same problem here, may clonk sound after shifting and releasing the clutch, even at full stop, handbrake on, when i shift to any gear then back to neutral, when releasing the clutch there is a "clonk" sound, help
    Dec 2007
    Quote Originally Posted by Bandido_04 View Post
    sir anong kotse niyo po?
    aite, peace.
    Nov 2003
    check the engine supports imo. one or some of them could be busted na.
    yung tranny support naman pinapalitan ko
    Feb 2005
    kbr, civic 96 po
    speedyfix, miski nakahinto basta nagshift to any gear then balik sa neutral, pag release ng clutch may clonk sound
    ty!
    Dec 2007
    kbr, civic 96 po
    ty!
    I see, well if its a Civic (and some FWD cars) then heres an example of parts that would cause some knocking sounds/noises while idling or driving.
    -worn / loose Transmission or Engine mounts (check the rear Tranny Mount on the Civic, since that part usually wears out)
    -worn Shift Linkage bushings.
    -worn Axles (Axle Shaft / CV joint..)
    -worn / loose Suspension Bushings and Ball Joints.
    anywayz there are some other parts that can cause unusual noises while idling or driving.. but in your case, it muna ang nilista ko. hope this helps.
    aite, peace.
    Nov 2003
    have it physically inspected. that is the best way to know.
    Already replaced the transmission support (P550 lang pala OEM BTW, total cost ko was P1,050.00 lang dala tune up hehehe). Nawala na ang clonking sound. Thanks Sir KBR, syur and speedy!
    Jan 2008
    sa akin po parang sa loob ng clutch mismo ung tunog, sa may pressure plate at clutch disc.
    Nov 2003
    550 oem? that's really cheap. i don't think i've seen any oem supports for that price.
    Yup sir speedy. Naka plastic pa nga na SGP (Suzuki Genuine Parts).
    Nov 2003
    cool! good deal!
    Aug 2007
    im having similar problem when shifting gear but not as often as the problem originally posted here.. also, i noticed that the shift knob (hope i used the right term for "kambyo") gets hot when driving for several hours, 2-4 hrs continous driving.
    any suggestion is greatly appreciated!
    btw, i have a honda city exi 97
    Aug 2007
    i think normal lang uminit ang shift knob. siguro naman hindi sobrang init na parang mapapaso ka na
    Aug 2007
    Quote Originally Posted by glenngj View Post
    ay hindi naman ako napapaso.. pro mainit lang sya.. kapag natry ko nag magdrive ng mga 6-8hrs, i-observe ko.. tamad lang kasi ako magdrive e!
Knocking sound when shifting gears
